Bayliss Boatworks new construction updates: Sequentis 60', Max Bet 64' and Bayliss 75'
by Bayliss Boatworks 2 Aug 2023 19:52 UTC
Bayliss 60' Sequentis © Bayliss Boatworks
The mezzanine and bridge buildout on Sequentis kept our exterior carpentry crew busy this past month. Storage and seating can be seen on the bridge now, and fabrication on the forward bridge storage compartments has begun.
In the lower accommodations, our electrical team started wire runs and the mechanical department installed the chiller lines.
Read more about the Sequentis
Bayliss 64' Max Bet
Max Bet's exterior saw some major changes this past month. The final planking to the bow deck was completed, and our paint crews then applied Awlfair and have sanded the bow deck.
Our exterior carpentry crew installed the cockpit structural deck, insulation, and AC plenum. In Max Bet's interior, our electrical and mechanical teams have been working on installing wire runs, chiller lines, and getting the air handlers in place.
Read more about the Max Bet
Bayliss 75'
The machine tunnel buildout is well under way on Bayliss 75'. Over in the hull shop, our carpentry crews wrapped up glassing in the machine tunnel, and they have handed it over to the paint crew to begin fairing and spraying the boxes.
While the paint team is working in the machine tunnel, our hull carpentry crew will begin fabricating the machine tunnel deck. On the hull, sanding continues and the bow thruster diverter has been installed.
Read more about the Bayliss 75'
Progress on Sequentis 60', Max Bet 64' and Bayliss 75' All the pieces are coming together on the 60' walkaround. Last month on Sequentis, the cockpit structural decking was installed, and epoxy was applied to the interior walls. Posted on 2 Jun 2023
