25 different switch models for any marine application
by Martin Flory Group 25 Jan 2018 21:21 UTC
Hubbell Toggle and Rocker Switches © Martin Flory Group
Often overlooked, quality switches are an important element of any 12V DC electrical system. Hubbell Marine offers 25 models of durable rocker, toggle and push-button switches made specifically for marine use and designed to complement any boat décor.
Hubbell Toggle and Rocker Switches are available in a wide variety of configurations to meet any application, such as bilge blowers and pumps, gauges, lights, starters, trim tabs, winches, windlasses and wipers. Single and double pole, and single or double throw are offered, as are a broad assortment of on, off, and momentary switching options.
Toggle Switches fit industry standard 13mm mounting holes in panels up to 48mm thick when using the included back-up nut, or 6mm without. They're available in black, with a red or green lighted lever, and with an illuminated red tip. An optional silicone rubber boot bonded to a brass nut provides a positive seal against moisture and dust.
Rocker Switches require a 38mm x 22mm rectangular cutout. They're available non-illuminated or with a built-in pilot light for night vision.
Hubbell's Push-Button Horn Switch has a 12mm nickel-plated brass mounting stem; terminals are 6mm spades for simple installation. A rubber boot is available for use in exposed locations.
For more information contact Hubbell Marine Electrical Products, Tel: +1-475-882-4838; Fax: +1-203-783-9195 or visit www.hubbell-marine.com.
