by Hubbell Marine 6 Apr 2022 15:22 UTC
New Stainless Inlets Speed Watertight Connections © Hubbell Marine
Seasoned mariners know that watertight integrity is critical for reliable shore power connections. Stainless steel 30A and 50A inlets from Hubbell Marine assure dependable performance in a timeless design that now benefits from recent technical updates.
Hubbell 125V Twist-Lock ship-to-shore inlets now incorporate a self-supporting hinge configuration that holds the cover clear of the cord set when in use. They also feature an upgraded recessed thread design that provides faster connections while ensuring a completely watertight seal.
Durable 316 stainless steel construction delivers a long service life. Nickel-plated brass contact blades and a polycarbonate interior provide the 2-pole, 3-wire inlets with superior heat-resistance. Hubbell's use of corrosion-resistant materials helps each device withstand the harsh elements, especially saltwater environments.
Available in 30A and 50A models, Hubbell Twist-Lock inlets are fully compatible with existing Hubbell cord sets. Both UL and cUL listed, they can be used on boats as well as on shoreline installations at marinas. Utilizing a 60.45mm mounting hole to match existing patterns for an easy retrofit, the new inlets are supplied with mounting screws, a waterproofing gasket and rear enclosure strain relief.
For more information contact Hubbell Marine Electrical Products visit www.hubbell-marine.com.
Hubbell Cable Sets deliver safety features
Twist-Lock 50A Cable play an important role in enhancing dockside safety for boat owners Despite a marina owner's best efforts, electrical problems at the pedestal may not be immediately diagnosed. Posted on 4 Aug 2023
Hubbell Marine offers a full line of components designed expressly for DC-powered reels Electric reels are popular with offshore fishermen in spite of sometimes being awkward to connect to a power supply. Posted on 16 Feb 2023
USB Receptacles keep phones and tablets charged
Now including USB Type A or Type C ports With both boats and boaters having become more connected than ever, there's never been greater need to keep portable devices fully charged while under way. Posted on 17 Mar 2022
Circuit Tester simple to use
LEDs on Hubbell Marine HBLT26CM11 Twist-Lock Circuit Tester glow bright enough to be seen in sun Multimeters are ideal for testing electric wiring, but their use requires specialized knowledge. Not so with the HBLT26CM11 Twist-LockĀ® Circuit Tester from Hubbell Marine. Posted on 5 Feb 2022
