USB Receptacles keep phones and tablets charged at sea
by Hubbell Marine 17 Mar 2022 17:03 UTC
With both boats and boaters having become more connected than ever, there's never been greater need to keep portable devices fully charged while under way. USB Charger Receptacles from Hubbell Marine include USB Type A or Type C ports within a traditional duplex outlet for the neatest possible installations and unbeatable convenience.
Hubbell offers a choice of three styles: two Type A USB ports, two Type C or one of each, all in combination with two standard three-prong outlets. These duplex receptacles deliver 5A and 5 volts of power to charge two devices simultaneously on the USB ports while retaining everyday usability with standard electrical devices. All comply with battery charging specification BC1.2 and are fully compatible with USB 1.1/2.0/3.0 devices, including Apple® products.
The USB ports are constructed with durable stainless steel and rated for 10,000 plug insertions and removals. They feature an integrated LED that confirms USB and line voltage power availability. A choice of ivory, white or light almond finishes allow the receptacles to work with a wide range of interior décors, either in new build or retrofit applications. Black, brown or gray finishes are available as special orders.
For outdoor spaces like boat cockpits and flybridges, Hubbell also offers a Weather Resistant USB Charger Receptacle in the combination Type A and Type C configuration. It incorporates a green LED power indicator and comes in either 15A or 20A versions in white, almond or ivory. Weather resistant models are fully compliant with section 406.9 of the National Electrical Code when used with covers.
For more information visit www.hubbell-marine.com.
Hubbell Cable Sets deliver safety features
Twist-Lock 50A Cable play an important role in enhancing dockside safety for boat owners Despite a marina owner's best efforts, electrical problems at the pedestal may not be immediately diagnosed. Posted on 4 Aug 2023
Hubbell Marine offers a full line of components designed expressly for DC-powered reels Electric reels are popular with offshore fishermen in spite of sometimes being awkward to connect to a power supply. Posted on 16 Feb 2023
Durable 316 stainless steel construction delivers a long service life Seasoned mariners know that watertight integrity is critical for reliable shore power connections. Stainless steel 30A and 50A inlets from Hubbell Marine assure dependable performance in a timeless design that now benefits from recent technical updates. Posted on 6 Apr 2022
Circuit Tester simple to use
LEDs on Hubbell Marine HBLT26CM11 Twist-Lock Circuit Tester glow bright enough to be seen in sun Multimeters are ideal for testing electric wiring, but their use requires specialized knowledge. Not so with the HBLT26CM11 Twist-Lock® Circuit Tester from Hubbell Marine. Posted on 5 Feb 2022
