Hubbell Cable Sets deliver illuminating safety features
by Hubbell Marine 4 Aug 2023 20:50 UTC
Twist-Lock 50A Cable © Hubbell Marine
Despite a marina owner's best efforts, electrical problems at the pedestal may not be immediately diagnosed. Twist-Lock 50A Cable Sets from Hubbell Marine play an important role in enhancing dockside safety for boat owners, by incorporating bright LED indicators that provide clear and immediate assurance of proper connection.
Engineered to withstand the harsh marine environment, Hubbell 50A Cable Sets provide outstanding quality and reliability. Each features a fully-molded ergonomic housing incorporating a nickel-plated brass shell for superior waterproofing and corrosion resistance. A stainless steel threaded sealing ring assures a weathertight fit against the shore power inlet.
An integrated arrow on the housing facilitates proper alignment, and notches indicate locked and unlocked positions. The bright, molded-in LED lights are visible even in direct sunlight, glowing green to confirm power flow and red in the event of a faulty hookup.
On the inside, Hubbell 50A Cable Sets feature thermoset contact carriers resistant to arcing and heat, along with nickel-plated brass contact blades for reliable operation. An integrated bull ring in the cord terminal provides stress relief in use, while an exclusive copper crimp barrel termination protects against overheating.
The cords themselves are designed to remain flexible, coil easily and lay flat. Marine UL and cUL listed, Hubbell Marine 50A twist-lock cable sets with LED safety indicators are available in yellow 125V models either 15.2m or 7.6m long, as well as in 125/250V versions in yellow or white, in 15.2m or 7.6m lengths.
For more information visit www.hubbell-marine.com.
Hubbell Marine offers a full line of components designed expressly for DC-powered reels Electric reels are popular with offshore fishermen in spite of sometimes being awkward to connect to a power supply. Posted on 16 Feb 2023
Durable 316 stainless steel construction delivers a long service life Seasoned mariners know that watertight integrity is critical for reliable shore power connections. Stainless steel 30A and 50A inlets from Hubbell Marine assure dependable performance in a timeless design that now benefits from recent technical updates. Posted on 6 Apr 2022
USB Receptacles keep phones and tablets charged
Now including USB Type A or Type C ports With both boats and boaters having become more connected than ever, there's never been greater need to keep portable devices fully charged while under way. Posted on 17 Mar 2022
Circuit Tester simple to use
LEDs on Hubbell Marine HBLT26CM11 Twist-Lock Circuit Tester glow bright enough to be seen in sun Multimeters are ideal for testing electric wiring, but their use requires specialized knowledge. Not so with the HBLT26CM11 Twist-LockĀ® Circuit Tester from Hubbell Marine. Posted on 5 Feb 2022
