Circuit Tester simple to use, provides valuable information
by Hubbell Marine 5 Feb 2022 19:19 UTC
Hubbell Marine HBLT26CM11 Twist-Lock Circuit Tester © Hubbell Marine
Multimeters are ideal for testing electric wiring, but their use requires specialized knowledge. Not so with the HBLT26CM11 Twist-Lock® Circuit Tester from Hubbell Marine. By simply plugging the device into a 20A or 30A 125V receptacle, colored LEDs illustrate whether the connection is correct, or whether there's an unsafe circuit condition that needs attention.
UL 1436 and C-UL listed, the Twist-Lock Circuit Tester features a patented design that's styled and sized like a Hubbell Twist-Lock Plug. Easy to find if dropped in a dark or cramped location, the durable housing is made from bright yellow Insulgrip® nylon.
The LEDs on the Hubbell Marine HBLT26CM11 Twist-Lock Circuit Tester glow bright enough to be seen in full sun. Attached to the device is a two-sided plastic card to interpret the seven possible combinations of colored lights, including dangerous open grounds and reverse polarity conditions. A carabiner is included to clip the tester to a tool belt.
For more information visit www.hubbell-marine.com.
Hubbell Cable Sets deliver safety features
Twist-Lock 50A Cable play an important role in enhancing dockside safety for boat owners Despite a marina owner's best efforts, electrical problems at the pedestal may not be immediately diagnosed. Posted on 4 Aug 2023
Hubbell Marine offers a full line of components designed expressly for DC-powered reels Electric reels are popular with offshore fishermen in spite of sometimes being awkward to connect to a power supply. Posted on 16 Feb 2023
Durable 316 stainless steel construction delivers a long service life Seasoned mariners know that watertight integrity is critical for reliable shore power connections. Stainless steel 30A and 50A inlets from Hubbell Marine assure dependable performance in a timeless design that now benefits from recent technical updates. Posted on 6 Apr 2022
USB Receptacles keep phones and tablets charged
Now including USB Type A or Type C ports With both boats and boaters having become more connected than ever, there's never been greater need to keep portable devices fully charged while under way. Posted on 17 Mar 2022
