by Hubbell Marine 16 Feb 2023 16:59 UTC
Hubbell's 30A, 28V © Hubbell Marine
Electric reels are popular with offshore fishermen in spite of sometimes being awkward to connect to a power supply. To assure a convenient, safe way to operate these popular devices, Hubbell Marine offers a full line of components designed expressly for DC-powered reels.
As the first to market with such a system, Hubbell's 30A, 28V solution provides a safer and more convenient means to power all 12V, 24V and 32V DC electric fishing reels, compared to battery clamp connections. The product line includes a corrosion-resistant plug, connector body and receptacle that fit a range of standard Hubbell boxes and covers to match the look of the boat's existing electrical components. Its unique plug configuration protects against the dangerous possibility of accidental connection with AC devices.
Crafted with nickel-plated contacts for corrosion resistance and durable nylon bodies that withstand both impact and UV exposure, Hubbell's electric fishing reel components are UL listed and CSA certified. Receptacles, plugs and housings are available in high visibility yellow or elegant white to suit any boat's décor, with boxes and spring-loaded lift covers also in gray.
For more information visit www.hubbell-marine.com.
Hubbell Cable Sets deliver safety features
Twist-Lock 50A Cable play an important role in enhancing dockside safety for boat owners Despite a marina owner's best efforts, electrical problems at the pedestal may not be immediately diagnosed. Posted on 4 Aug 2023
Durable 316 stainless steel construction delivers a long service life Seasoned mariners know that watertight integrity is critical for reliable shore power connections. Stainless steel 30A and 50A inlets from Hubbell Marine assure dependable performance in a timeless design that now benefits from recent technical updates. Posted on 6 Apr 2022
USB Receptacles keep phones and tablets charged
Now including USB Type A or Type C ports With both boats and boaters having become more connected than ever, there's never been greater need to keep portable devices fully charged while under way. Posted on 17 Mar 2022
Circuit Tester simple to use
LEDs on Hubbell Marine HBLT26CM11 Twist-Lock Circuit Tester glow bright enough to be seen in sun Multimeters are ideal for testing electric wiring, but their use requires specialized knowledge. Not so with the HBLT26CM11 Twist-Lock® Circuit Tester from Hubbell Marine. Posted on 5 Feb 2022
