by Connect-Ease 19 Apr 16:03 UTC
Photo courtesty of Norsk Lithium
Connect-Ease® GRAPH POWER® kits offer anglers plug & play solutions for rigging todays advanced fishing electronics and the brightest, cleanest imaging possible
Weve all been thereeither standing at the boat dealer wondering if we should have a professional rigger install all the new fishing electronics we purchaseddo it ourselves in the garageor convince friends to help who might know a lot more about rigging than we do
No matter what category you fall into, theres a boat rigging system that reduces labor costs with dealer services or professional riggers, on our own in the shop, or with buddies whove rigged more boats than maybe we have. And no more trips to the hardware store to find components they probably dont have in the first place.
Connect-Ease® GRAPH POWER® kits were designed specifically to reduce hours spent rigging into minutes. The three GRAPH POWER kits available provide systems that work with any 19- to 22-foot console fishing boat; 14- to 18-foot console fishing boat; and tiller fishing boats.
Not only does GRAPH POWER provide hassle-free rigging, the systems were designed to ensure todays graphs and other fish-finding technologies works exactly as they should, providing the brightest and most crisp imaging possible, especially with the latest in Forward-Facing Sonar. Whether you use Garmin LiveScope, Humminbird MEGA Live and/or MEGA 360, or Lowrance Active Target 1 or 2or a combination of brandsGRAPH POWER is designed to get optimal performance out of all, maximizing your investment and helping you see your bait and fish better, resulting in a better fishing experience altogether.
Wisconsin-based pro walleye angler and Connect-Ease pro staffer, Brett King, has been fishing tournaments for over 25 years and relies on Connect-Ease GRAPH POWER PRO to ensure his electronics work just as they should during the mission-critical hours and minutes of professional tournamentsand to keep his Lowrance units as bright and crisp as possible from dusk til dawn (with the help of quality lithium batteries, of course).
Connect-Ease Founder, Cal Munkvold, remarks: Ive been a big-water angler my entire life, so I knew there had to be a better way to rig electronics for everyone from the weekend warrior to the serious tournament angler. So we sat down and designed the trouble-free solution we would want to buy and install. Along the way, weve addressed issues that anglers have had maintaining bright and clear graph imaging, too, which can be the difference between hero and zero. Weve also designed products that allow easy, hassle-free rigging and powering of trolling motors, too, for optimum performance, whether youre running and older model or one of todays direct-drive, brushless, and GPS- and features-rich models.
ABOUT CONNECT-EASE® GRAPH POWER®
GRAPH POWER was designed to solve the connections and power issues associated with running todays sophisticated fishing electronics common on todays boats, providing clear, clean power and direct connections.
GRAPH POWER is designed to work with all manufacturers of fresh- and saltwater marine electronics. GRAPH POWER features marine-grade sheathed wire with multiple fused connections for your console and bow electronics.
Connect-Ease uses the best marine-grade connections and heat-shrinkable crimped connections that are waterproof, reject RF interference, and stay connected on big water and waves. There is a 30 amp fuse at the battery and your choice of 3 or 5 amp fuses to use at the graph connections.
GRAPH POWER PRO FEATURES (19-22 CONSOLE BOAT KIT)
  • HOUSE CONNECTION: 30 Amp fused quick-snap connection at the batteryno switch needed
  • EASY FEED DESIGN: Bullet connections and sheathed housing for hassle-free installation and snaking through tight spaces
  • PRO CONSOLE BACKBONE: 16 feet of 8 gauge sheathed marine-grade wire
  • PRO BOW BACKBONE: 13 feet of 8 gauge sheathed marine-grade wire
  • DEVICE PROTECTION: Your choice of 3 or 5 Amp at the fused connections to meet manufacturer recommendations
  • HEAT SHRINKABLE BUTT SPLICES: Weatherproof, vibration-, and corrosion-free for a lifetime of on-the-water use
  • LITHIUM BATTERY COMPATIBLE
GRAPH POWER RIGGER FEATURES (14-18 RIGGER BOAT KIT)
  • HOUSE CONNECTION: 30 Amp fused with quick-snap connection at the batteryno switch needed
  • RIGGER CONSOLE BACKBONE: 13 feet of 8 gauge sheathed marine-grade wire
  • RIGGER BOW BACKBONE: 8 feet of 10 gauge sheathed marine-grade wire
GRAPH POWER TILLER FEATURES
  • TILLER BACKBONE: 10 feet of 10 gauge nylon-sheathed marine-grade wire for protection and to limit RF interference
  • DEVICE PROTECTION: Your choice of three 3 or 5 Amp fused connections to meet manufacturer recommendations of todays graphs, pucks, GPS, and NMEA boxes directly from your battery
Photo courtesy of Norsk Lithium
Not only do Connect-Ease GRAPH POWER kits make rigging fast and simple, they provides protection and limits RF interference to power your graphs, pucks, GPS, and NMEA boxes directly from your battery to meet manufacturer recommendations.
Not only is rigging faster and trouble-free, you get the best possible clear and defined imaging on your graphs once installed, especially helpful with side-, down-, and forward-looking sonar technologies. GRAPH POWER was designed to provide clean, reliable power to the critical and power-hungry electronics found on todays tournament boats, so that translates to the very best rigging solution for every customer, no matter how often youre on the water.
Our pro anglers and guides have learned through years of experience that to get the best performance out of todays electronics, its best to use any GRAPH POWER kit connected directly to its own dedicated lithium battery.
For more information, visit www.connect-ease.com.
FacebookYouTubeInstagram
