Plug & play rigging for today's advanced trolling motors
by Connect-Ease 19 Mar 15:09 UTC
Plug & Play Rigging for Todays Advanced Trolling Motors
Connect-Ease® 2.0 PRO Trolling Connection Kits provide anglers with reliable, plug & play rigging systems (w/onboard charging) for todays newest trolling motors & lithium or AGM batteries
For anglers running todays newest brushed or brushless, direct-drive, and more powerful 12-, 24-, and 36-volt bow-mount trolling motors, Connect-Ease® is proud to introduce the Connect-Ease 2.0 PRO Trolling Motor Connection Kit w/Onboard Charging, which features heavier-duty 6-gauge wire and many other engineering advances.
For 36-volt trolling motors like the new Minn Kota QUEST Series, Garmin Force Kraken,  Lowrance GHOST, Power-Pole MOVE, MotorGuide Tour Pro, and Rhodan models, the Connect-Ease 2.0 36V Series PRO Trolling Motor Connection Kit W/Onboard Charging is incredibly easy-to-install, protects your investment, and offers peace of mind while fishing mission-critical, tournament or big water situations.
But you dont have to be a pro angler to utilize the new Connect-Ease 2.0 kitany angler or boater who simply wants his boat or pontoon to work perfectly every time on the waterwill benefit from a Connect-Ease 2.0 Pro Trolling Motor Connection Kit w/Onboard Charging
Whats Included: NEW Connect-Ease 2.0 (RCE36VPRO) 36V Trolling Motor/Charger Kit
The Connect-Ease 2.0 PRO 36V Trolling Motor/Charger Kit includes three 12-volt battery series connections and charger leads to connect both your bow-mount trolling motor and onboard charger.
While the components could be considered over-engineered, Connect-Ease 2.0s mission was to provide a no-fail power distribution network no matter what kind of on-the-water situations you encounter, from fishing the Great Lakes or heavy current river fisheries to a weekend off work relaxing on the pontoon or skiff.
Fact: Believe it or not, but a lot of boat manufacturers, dealers, and riggers do not use marine-grade wire.
On the contrary, every Connect-Ease 2.0 PRO 36V Series Pro Trolling Motor Connection Kit w/Onboard Charging includes thick, efficient, and long-lasting 6-gauge (AWG) marine-grade tinned copper wire and components that protect from corrosion, electrolysis, and fatigue due to boat vibration and flexing in waves and wind. Heavy-duty insulation offers additional heat, cold, abrasion, and vibration resistance.
In fact, Connect-Ease 6-gauge (AWG) marine-grade wire exceeds all UL 1426 U.S. Coast Guard Charter Boat and ABYC standards, something we didnt have to do, but did.
While it cost us more at the onset, we built-these professional components into the new kit because we wanted all anglers and boaters to benefit from the same, pro-grade materials we use in our own 36-volt trolling motor rigging for problem-free operation in critical fishing and boating situationsfrom big league bass/walleye tournaments to hard-earned time-off-work.
Additionally, the Connect-Ease 2.0 36V Series PRO Trolling Motor Connection Kit w/Onboard Charging includes a 60 amp Resettable Circuit Breaker and Negative Connection Block with direct connection leads and heat-shrinkable butt splices to quickly and securely connect the kit to chargers manufactured by Minn Kota, NoCo, PowerPole, Battery Tender, Dakota Lithium and countless others.
The end result for the angler/boater?
Youll never have to worry about your 36-volt trolling motor being powered correctly again with Connect-Ease 2.0 PRO.
Whether youre running standard or new, high-output Minn Kota QUEST, Garmin Force Kraken, Lowrance Ghost, Power-Pole MOVE, or MotorGuide Tour Grade 24- and 36-volt trolling motors, what you get with the Connect-Ease 2.0 Pro Trolling Motor Connection Kits w/Onboard Charging is pure, clean power from your batteries to the trolling motor and charger, end of story.
For anglers running 24V trolling motors, the Connect-Ease 2.0 PRO 24V Pro Trolling Motor Kit (RCE24VPROCHK) offers similar advantages with onboard charging and lithium compatibility.
Talking specs, both the new Connect-Ease 2.0 24V and 36V Series PRO Trolling Motor Connection Kits w/Onboard Charging will distribute and manage up to 150 amps of power.
Whether youre going to rig a new boat, re-rig an older boat, or seek out marine professionals to help you switch out trolling motor batteries, power distribution, and marine electronics for the season, Connect-Ease products promise problem-free operation of todays latest and greatest, from todays more powerful and advanced trolling motors to forward-facing sonar technologies.
We like to say: More time fishing, less time rigging
FacebookYouTubeInstagram
