by Shurhold 7 May 20:34 UTC
Shurhold Brite Wash and Pro Polish Wax & Sealant © Shurhold
If there's one boat detailing tip long-time owners regularly share, it's to choose quality tools. The combination of Shurhold Brite Wash and Pro Polish Wax & Sealant is a great example. Not only are they more effective together, cutting the time needed to complete the job, but they provide showroom-quality results that last for months.
Brite Wash is scientifically formulated to clean boat exteriors that are continually exposed to the elements. Unlike traditional waxes that use powdered talc, Pro Polish Wax & Sealant is an advanced, highly-concentrated polymer formula to glide on smoothly and quickly. It then seals the surface with a water-repellent and UV-resistant protective finish.
Powerfully cleaning dirt, grease and salt from hard surfaces like gelcoat, paint and metal, it's also safe to use on non-porous surfaces like isinglass, plastic, rubber and vinyl. Unlike harsh soaps meant for other purposes, it won't dull the surface finish or strip wax. Biodegradable, Brite Wash can be rinsed overboard without damage to the environment.
Brite Wash and Pro Polish are professional grade so less material is needed to achieve expert results. This makes the products more cost-effective in the long run, and also means less time working and more time enjoying the showroom shine.
Inventor of the One-Handle-Does-It-All-System, Shurhold is the leading manufacturer of professional-grade detailing supplies that help clean, polish and protect vessels. Dedicated to educating boat owners, Shurhold provides key tips for boat value preservation at shurhold.com.
For more information contact Shurhold, +1-772-287-1313; Fax: +1-772-286-9620. shurhold.com.
