Pantaenius 2022 - FISH LEADERBOARD
IMOCA becomes the first class in sailing to introduce an impact reduction rule on boat construction
by Ed Gorman / IMOCA Globe Series 20 Apr 17:31 UTC
Annual General Meeting of the IMOCA Class © Marin Le Roux / polaRYSE / IMOCA
In brief:
  • IMOCA establishes pioneering impact reduction rule, leading sustainability in sailing by requiring a 15% reduction in boat's construction emissions between 2025 and 2028.
  • The initiative marks a historic shift in the maritime industry, with an emphasis on minimising environmental impact through changes in materials and design processes, particularly targeting carbon fibre intensive components like hulls, decks, and foils.
An impact reduction rule limiting harmful emissions in boat construction has been the major goal of the sustainability work that IMOCA has been conducting over the last four years and now it is being implemented.
At this week's Annual General Meeting of the Class in Lorient in Brittany, the skippers and teams formally endorsed a new regime that will require all new boat builds in IMOCA undertaken between 2025 and 2028 to reduce harmful emissions by 15%.
This is something that no other class in the sport of sailing has achieved and represents a historic step forward in bringing IMOCA activity, and the industry that supports it, in line with public sentiment on the crisis facing our planet.
Antoine Mermod, President of the IMOCA Class, said an impact reduction rule has now become a reality after several years of research and consultations with skippers, teams, naval architects, boatyards, suppliers and commercial partners.
"With an impact reduction rule now in place we are pushing the teams when they are building a new boat to choose ways that minimise the impact of that process," said Mermod.
"This will change the way we operate, but also change the maritime industry that supports us who are very happy to follow us. Even if it is not very spectacular to say that, this is what we are doing," he added, "it is a very, very important moment and a huge move for the future of our industry."
Damien Seguin, the Groupe APICIL skipper, said the adoption of the rule is a positive step not only for IMOCA but offshore racing as whole and potentially the entire nautical industry that sends a clear signal to everyone. "I think it's great and courageous that this has been done and voted on," he said.
"This marks a turning point in the history of the Class, as it will likely influence architectural choices throughout the decision-making chain, from the skippers to the architects, design teams and shipyards," added Seguin."The aim is to reduce our environmental impact, particularly by limiting the use of carbon in boat construction and related components."
The long road to the imposition of an impact reduction rule has seen the Class use Life Cycle Assessment, or LCAs, on all recent new boat builds to understand the full extent of their environmental impact. The next step was to identify the key areas where emissions could be reduced and then develop a piece of software, dubbed the "Eco-Conception Tool," to help designers and boat-builders understand how they can make reductions in emissions to hit the 15% reduction target.
"From all of our LCA analysis, we identified three hotspots where reductions could be made - the boat moulds, the platforms (hull, deck and internal structure), and the foils," said Imogen Dinham-Price, Sustainability Manager at IMOCA.
"We saw that the moulds accounted for 44% of total emissions, foils came out at 13% with the platform at 32%. The Eco-Conception Tool allows designers and teams to play around with different scenarios, so they can reduce their impact by determining the quality of different materials they use in each of those three areas."
In all new builds from now on we can expect to see teams using less carbon-fibre - and particularly intermediate-modulus carbon-fibre which is emission-intensive - in hull moulds, in deck moulds, deck structures and foils. Instead alternatives will be used such as glass-fibre or standard modulus carbon.
Noémie Provost, Technical and LCA Manager at IMOCA, says she does not believe there will be a performance penalty for new boats hitting their emission targets under the rule."We think that architects will find new boat and foil shapes to continue to be competitive. They have a lot of software to analyse hull and foil shapes and they should be able to find improved performance as before," she said.
Both Provost and Dinham-Price who, along with Samuel Valverde, have led IMOCA's work on the new restrictions, believe the teams will achieve the reductions as set out in the rule. They say most of them recognise it is a response to an issue which the Class must address. "We have teams that say 'yes, we need to go in this direction if we want our sport to continue through this transition to less impactful boat construction,'" Provost summarised.
The Class says the new regime should cut costs because there will be less use of the most expensive materials. However, if a boat does not conform to the restrictions as set out in the rule, penalties will be applied that could, for example, restrict the numbers of foils a boat can use or reduce its allocation of new sails.
In the long run the Class's ambition is to build on this first step after 2028. "The goal is to continue to reduce emissions," said Provost. "Maybe 15% more between 2028 and 2032. And maybe as well, by continuing to use the LCAs, we will be able to determine if this rule works well or not because we will be able to assess the next builds and understand their impact, so we will have some new data to set new objectives."
Dinham-Price says IMOCA is leading an industry that "is changing and going in the right direction." She says the Class is taking the initiative in an area of the economy that is not controlled by government-set targets."We are setting our own agenda," she said. "That is producing an enormous amount of cooperation and understanding of the global situation within our industry.
"And it won't just be the Class that benefits," she added, "because if we have the possibility of changing and adapting one small process - for example, adding flax to our moulds or having foils built with less waste - these changes will reflect a whole industry involvement behind them."
Seguin said implementing the impact reduction regime will be challenging, but he believes the Class has the resources to ensure it will be a success."Within the Class, there are individuals who will help understand this rule thoroughly, because it's not as simple as it seems to grasp all the different reduction percentages we want to achieve and how it fits into projects seamlessly," he said.
"The Class supports teams and the thought process to calibrate all of this. I'm convinced that we have a strong and innovative tool at our disposal, and now it's just a matter of putting it into practice. I have little doubt that in the future, other classes will closely monitor what we do and align with this model," he added.
IMOCA Class Sailor Profile: Sam Goodchild
Who is this modest 34-year-old Englishman? In the history of the IMOCA Class there have been few skippers who have completed a debut year to rival that of Sam Goodchild, who achieved five consecutive podium finishes in his first five races and became the 2023 IMOCA Globe Series Champion. Posted on 16 May
The Vendée Globe switches to American time
The New York Vendée Les Sables d'Olonne will set sail in 15 days time The last qualifying and selection race for the solo round the world race, the New York Vendée Les Sables d'Olonne, will set sail in 15 days time, on 29 May, at 20h00 French time. Posted on 14 May
11th Hour Racing sponsors IMOCA
To further advance sustainability and diversity in offshore racing 11th Hour Racing announced today it will join forces with the International Monohull Open Class Association (IMOCA) to drive sustainable innovation and support opportunities for female sailors within competitive sailing. Posted on 14 May
Perseverance is Clarisse Crémer's middle name
Back racing hard in The Transat CIC and today is some 700 miles from the finish line After a strong, solid start to the Transat CIC, Clarisse Crémer suffered damage to the J3 bulkhead of her L'Occitaine en Provence on May 1st which required her to divert 500 miles to the Azores for five days whilst her technical team completed repairs. Posted on 14 May
The Transat CIC Prizegiving
Podium finishers honoured Competitors and invited guests honoured the IMOCA and Class40 podiums of the 15th edition of The Transat CIC at the prizegiving Sunday in New York. Posted on 13 May
The Transat CIC Update
New York offers finishers sunshine but still dark clouds over the Atlantic At 13 days since the fleet left Lorient just seven solo racers are still racing across the Atlantic on the 3,500 miles Transat CIC. Posted on 11 May
Giancarlo crosses the Transat CIC finish line
A tough test prior to the Vendée Globe 2024-2025 Giancarlo Pedote crossed the finish line of the Transat CIC 2024 at 22:07 hours (UTC) on Thursday 9 May after an epic crossing, which took him from Lorient to New York, putting both his skills as a sailor and his boat Prysmian to the test. Posted on 10 May
Clarisse Crémer resumes The Transat CIC
After a 5-day technical stopover in Horta After discovering a crack of over 4.20 meters on her boat during the race, Clarisse had to make a technical stopover in Horta for repairs last Monday. Posted on 10 May
Ambrogio Beccaria wins The Transat CIC in Class40
Crossing the line of the historic race at 03:47:55 hrs this morning Italy's Ambrogio Beccaria on his all Italian designed and built Musa 40 Alla Grande Pirelli added the hugely prestigious Transat CIC Class 40 title to his steadily growing collection of solo and short handed ocean racing honours this morning. Posted on 10 May
Team Holcim-PRB greets lady Liberty
Nicolas Lunven crossed the finish line of The Transat CIC Wednesday May 8th at 16:25 local time (22:25 CET), Nicolas Lunven crossed the finish line of The Transat CIC, 12 hours later the green and blue IMOCA sailed past the Statue of Liberty and the Manhattan skyline. Posted on 10 May
Pantaenius 2022 - FISH FOOTERSCIBS 2024 FOOTERSydney International Boat Show 2024
