Learn the benefits of using a braided line to leader combination
by Yoshinori Mitani, Sunline America 16 Mar 19:28 UTC
Braid with leader © Bassmaster
Braided line is becoming more and more popular on both baitcasting and spinning reels. While an angler can tie his or her lure straight to the braid, another option would be to use a fluorocarbon or nylon leader.
Sunline offers both FC Leader and Nylon Leader materials designed specifically for this. Another specific leader material called the Tepa Tapered FC Leader is a new one for 2023/2024. This line allows for an angler to do one of two things: (1) tie the stronger end of the leader to the braid to increase knot strength while keeping a thinner diameter by the lure, or (2) tie the thinner diameter of the leader to a small matching diameter braid while having more strength at the lure if fishing around structure. Bassmaster Elite Series pro angler Austin Felix has a lot of knowledge when it comes to using braid with a leader as he uses it with several different techniques that most anglers don't. Using straight braid is a necessity for techniques such as throwing a frog or flipping a punch rig in grass mats, but there are many other techniques that tying a fluorocarbon or nylon leader to braided line would be beneficial. Below are some benefits of doing this.
1. Low stretch
Braided line has zero to little stretch, which can be beneficial for techniques that require hard hooksets such as flipping a jig or Texas rig. Using a fluorocarbon leader tied to braid rather than using straight fluorocarbon will maximize hook penetration due to the braid's low stretch and superior strength. Felix claims that low stretch can also be beneficial for lures such as bladed jigs, lipless crankbaits, and swimming a worm when there is more grass than usual beneath the surface. In this scenario, less stretch allows for the angler to rip the lure out of the grass more effectively to give the lure its maximum performance.
2. More sensitivity
It can often be difficult to detect a bite when using fluorocarbon or nylon, especially when the fish are sluggish. Because braid has more sensitivity than fluorocarbon or nylon, it can be beneficial to use braid with a leader. Just as low stretch can be beneficial for ripping lures out of heavy submerged grass, Felix claims that having more sensitivity can also be a benefit for this technique so that an angler can tell the difference between what a bite feels like verses being hung in grass. For this technique, Felix prefers 30-pound green Siglon PEx8 paired with 16-20-pound Sniper fluorocarbon depending on how thick the grass is. He also claims that the PEx8 is smoother when it runs through the guides and it helps with feeling vibration.
3. Less visibility
Braided line isn't clear like fluorocarbon or nylon, so the fish are more likely to see it. Using a leader will help with this while still providing the low stretch, high sensitivity, and increase of casting distance that is crucial in certain situations. Using spinning rods with light lines is now very common on the Bassmaster Elite Series, especially when lakes are dominated with smallmouth or spotted bass. Felix has had great success using spinning setups as 7 of his 9 Elite Series top 10s (including his win at Lake Oahe in 2022) came from utilizing finesse techniques on spinning rods with light line. For spinning setups, Felix prefers a Sunline Sniper fluorocarbon leader tied to a high-vis pink sinking braid called Sunline Almight, soon to hit the market. He always uses braid-to-leader on his spinning combos and always matches the diameters together to prevent issues with casting or breakage. For instance, if he uses 7-pound braid he will use a 5-7-pound leader, 13-pound braid tied to an 8-10-pound leader, and 16-18-pound braid tied to a 15-pound leader when skipping docks or something that requires a short, accurate cast. Regarding the length of his leader, he always uses one long enough for his FG knot to still be in his reel before making a cast, usually 15 to 20 foot in length.
4. Less respooling
When flipping heavy cover, fluorocarbon can wear out quickly. Because of this, an angler might strip all the line off a baitcasting reel often, which can get expensive after a few fishing trips. One of the biggest benefits of braided line is that it lasts much longer than fluorocarbon or nylon which means it can be used longer without respooling. It is much cheaper to use a leader connected to braid rather than using straight fluorocarbon or nylon. When flipping, Felix always sets his drag loose enough for the line to give a few inches when he sets the hook so that it doesn't put too much stress on the FG knot. He uses orange 40-pound Siglon PEx8 braid tied to a 15-to-20-foot fluorocarbon leader, and the type of fluorocarbon depends on what type of cover he is fishing. Felix uses 15-pound Sniper tied to his braid when flipping a lighter jig, 20-pound Sniper tied to his braid when flipping submerged milfoil, and 22-25-pound Shooter tied to his braid when flipping docks because of its superior abrasion resistance. When his leader gets old, he saves money by replacing it rather than replacing all the line on the spool. To read about other ways to save money on fishing line, check out one of our recent blogs here.
5. Casts further
Braided line is slicker and thinner in diameter than fluorocarbon and nylon lines, which means that it goes through the rod guides easier resulting in further casting distance. If you want to increase your casting distance, use braid-to-leader rather than straight fluorocarbon or nylon. Casting a big topwater bait is one technique that requires long casts. For this technique, Felix prefers green 30-pound Siglon PEx4 braid tied to a 20-pound Super Natural Nylon Monofilament 3-foot leader to keep the braid from getting tangled up in the hooks.
Connector Knots
The most important thing to know when using braid with a leader is how to tie a connector knot. There are many different braid-to-leader connector knots along with other knots that can be tied. Check all of them out here. Felix uses an FG knot on his spinning and baitcasting braid-to-leader setups because of its strength and small diameter resulting in further casting distance.
Known as the ultimate power fishing angler, Jason Christie demands incredible strength and abrasion resistance in a fishing line to meet the challenges of heavy cover, short casts and explosive hook sets. Power2C was designed to Jason's specifications to meet the demands of shallow water, heavy cover angling. As a premium fluorocarbon, it features extreme abrasion resistance against wood, boat dock cables and rocks. It also features the perfect shock absorption to overcome wicked hook sets on big fish with heavy action rods at short distance to insure no break offs, which plagues many fluorocarbon lines. Finally, Power2C features repeating high visibility markings on the line to provide greater visibility for line watching, to be able to see the lightest bites. The high visibility marking is 12" long followed by 48" of clear, allowing you to tie on in the clear section like a leader while still having the benefits of high visibility during the retrieve. Fluorocarbon can also be very hard to see in dirty or stained water conditions, so the high visibility markings act like a tracer allowing you to easily see the line no matter the water color.
LB Test: 16, 18, 20, 22, 25
Spool Length: 165YD
Shop now
A 100% fluorocarbon line featuring our patented Pion Technology. Assassin is the first product launched in the US featuring Pion Technology. Pion processing improves slickness, abrasion resistance and longevity of your line by chemically altering the line's surface to allow resin processing to bond at a molecular level. This processing increases line performance and allows the line to retain key characteristics longer.
LB Test: 8, 10, 12, 15, 17, 20, 25
Spool Length: 225 YD, 660 YD
Shop now
Start your season off strong with Sunline
Sunline has you covered with multiple varieties of braided line in bulk spools Looking to bulk up during the off season and come out swinging at your first tournament of the year? Posted on 17 Jan
Get ready for that Fall bite with Sunline
Shooter is constructed using the highest quality materials Sunline Shooter isn't just for power fishing presentations! Marc Frazier likes to use the smaller lb tests for leader material on some of his finesse applications. Posted on 12 Sep 2023
See what's new from Sunline
Sunline JDM FC Sniper Invisible Fluorocarbon Line is incredibly effective around line-shy fish Sunline JDM FC Sniper Invisible Fluorocarbon Line delivers all of the outstanding properties of Sniper - now in a specially formulated, multi-color design that makes it stealthier than ever before. Posted on 16 Aug 2023
Sunline America news update
Save over 70% on Sunline Model braid is an eight-strand high performance braided line made in Japan that is available at extreme savings. An overstock in bulk braided line allowed these two popular sizes to be be made in 16LB and 60LB sizes. Posted on 22 Jun 2023
Prevent backlashes with helpful tips from Sunline
Getting a backlash can be extremely frustrating, especially when it happens during a tournament Getting a backlash can be extremely frustrating, especially when it happens during a tournament when there is no time to waste. Posted on 21 Mar 2023
Take back the night with Sunline Night FC
Sunline has designed the ultimate night fishing fluorocarbon line Being able to see your line is often critical in helping determine bites when your line is only swimming off after a subtle bite. Night fishing presents one of the greatest challenges to seeing your line effectively. Posted on 14 Jun 2022
Sunline pros continue to collect checks & trophies
What are you waiting on to use the line that champions use? Our Sunline pros have won seven major trophies already in 2022. What are you waiting on to use the line that champions use? Posted on 21 May 2022
5 Trophies 1 Line
Congratulations to Sunline pros Drew Cook, Jason Christie, Michael Neal and John Crews Congratulations to Sunline pros Drew Cook, Jason Christie, Michael Neal and John Crews on a great start to the 2022 season. We are proud to have these outstanding anglers on our team. Posted on 26 Apr 2022
Why you should use fluorocarbon fishing line
Fluorocarbon has some unique properties Super FC Sniper is Sunline America's best selling product for a reason. Our pros love Sniper for its' versatility and manageability. Sniper is a great choice for spinning or casting tackle. Posted on 20 Apr 2022
Three trophies, one line
The common denominator is Sunline! Congratulations to Sunline pros Drew Cook, Jason Christie, and John Crews on a great start to the 2022 season. We are proud to have these outstanding anglers on our team. Three trophies and the common denominator is Sunline! Posted on 30 Mar 2022
