Dripping shaft seal? It's time to service or maintain your propeller shaft seal!
by Marine Products Direct 12 Dec 2023 12:00 UTC
Lasdrop Gen II Shaft Seal © Marine Components International
It's maintenance season and the time of year when boats are lifted out for the winter, and those essential annual servicing jobs are undertaken. One key element to check and often overlooked is your propeller shaft seal, but it's key to ensure a dry bilge and minimise contaminated bilge water from entering the ocean and should be part of your yearly checks.
Here are some tips from Marine Products Direct on what to look for when it comes to replacing your shaft seal and why you should consider Lasdrop.
Lasdrop Dripless Shaft Seals offer an environmentally friendly solution to shaft seals preventing contaminated bilge water from entering the sea. A high-quality well fitted yacht shaft seal solution works two ways; it will keep water out and ensure engine and bilge water is kept onboard.
Lasdrop have designed their 'mechanical' and face 'lip seal' shaft seals as an extremely easy to fit and service solution. They require minimal maintenance and have design features that make in season checks and servicing far simpler and more cost effective. There is a propeller shaft seal solution for virtually every boat with three variants available:
Lasdrop EliteSeal is a high-quality lip seal designed for quick and easy installation and minimal ongoing maintenance. This option uses a Nitrile lip seal that is in constant low friction contact with the propeller shaft, preventing water from entering your vessel. The simple, affordable solution to a leaking tired stuffing box. The EliteSeal comes with a spare lip seal carrier and split face design allowing two spare seals to be stored on the tube, eliminating the need to remove the whole shaft seal to replace the lip seal.
Lasdrop DrySeal is a compact, economical lip seal designed for quick and easy installation. It offers all the features of the EliteSeal including the split face design. Spare seals are held loosely on the tube.
Lasdrop Gen II Shaft Seal A unique and extremely high-quality mechanical shaft seal. A ball-bearing drive system allows the seal ring to "float" and remain in constant contact with the carbon graphite seal surface, resulting in a seal that's impenetrable to water and extremely long lasting, around 10,000 engine hours of use. This seal is ideal for heavily used vessels such as commercial fishing boats.
Manufactured and designed in the USA, Lasdrop shaft seals are backed with a three-year warranty. Each model is easy to install, requires little or no maintenance, and is sold as a complete kit.
Facts
  • Long lasting
  • Easy to install
  • Simple during season maintenance
  • Both 'mechanical' and face 'lip seal' options available
  • Environmentally friendly dripless designs
  • All sizes offered in both metric and imperial
Find out more on Lasdrop from David Ellis of Marine Products Direct on this video featuring Lasdrop Shaft Seals or contact us for technical support, on +44 01202 600011 or email .
Find your local stockist at www.marinecomponents.co.uk or order now from marine-products-direct.com.
Easy Med Mooring with the GHOOK from Boatasy
Mooring astern made simple with Boatasy We all know the sailing world is full of strange terminology, and we are about to introduce a new one – Boatasy GHOOK. Posted on 30 Apr
I need to carry an anchor at my next regatta
Help! Where do I start? It's not uncommon these days for class or events to specify the need to carry an anchor on board for safety reasons. In fact, when sailing in tidal waters especially if unsupervised you could say it's always worth carrying one on board. Posted on 27 Mar
MCI appointed Exclusive UK Distributor for Mantus
Mantus Marine offer a full range of performance, quick setting anchors Marine Components International, leading supplier to the UK leisure and commercial marine market, has been appointed as the exclusive UK marine distributor for USA manufacturer of high performance, quick setting anchors Mantus Marine. Posted on 22 Mar
Docking made simple with Boatasy
The gamechanging modular boathook system from Boatasy For any boat owner, whether sailing fully crewed or shorthanded, one of the most challenging parts of any day on the water is the leaving and getting back to the dockside. Posted on 16 Feb
TEMO·1000 electric outboard motor defies the norm
Innovative, powerful, quiet and emmision-free TEMO are an innovative French company who look at solutions in a different way. We'd already taken a close look at the TEMO·450, with its extendable pole, rather than the traditional shape of engine housing at the top, and now we've tried the TEMO·1000. Posted on 2 Jan
Winter maintenance tips
Get ready for winter with these top tips from Marine Products International It's that time of year! Winterisation is now in full swing and around the yard essential maintenance work is being undertaken. Posted on 2 Dec 2023
EchoPilot FLS 3D Gen 4 now compatible with Axiom
Take a look at the new Forward Looking Sonar from Daniamant Calling all explorers and sailors who like to venture away from the conventional harbours and crowded anchorings - you need to learn more about the NEW Forward Looking Sonar from Daniamant. Posted on 4 Sep 2023
Say goodbye to your old traditional boat hook
Compact lightweight boat hook from MCI Say goodbye to your old traditional boat hook that corrodes and occupies significant space when not in use and say hello to the future in boat hook design, the Revolve-Tec Rollable Boat Hook available from Marine Components International. Posted on 20 Jul 2023
On Test: TEMO-450 portable electric outboard
Lightweight, IP67 waterproof, extendable pole provides a whole new option for your dinghy The TEMO-450 is a portable electric powered outboard, which differs substantially from other outboards on the market. Posted on 6 Jun 2023
