The Ocean Race In-Port Race in Aarhus, Denmark
by The Ocean Race 4 Jun 2023 14:51 UTC 4 June 2023
The Ocean Race 2022-23 - 4 June 2023. Biotherm wins In-Port Race in Aarhus © Sailing Energy / The Ocean Race
Biotherm and WindWhisper are the winners on a day of comebacks
The sun was shining on Sunday, as it has been throughout the entire Aarhus stopover, and that meant a building sea breeze would be the order of the day for the In Port Racing programme.
This marked the return of the VO65 class to The Ocean Race, as the fleet comes back to continue racing in the VO65 Sprint.
In the IMOCA class, with the overall race leaderboard so close at the top, the In-Port Race results take on greater importance as a tie-breaking mechanism for The Ocean Race.
It was a day of comebacks, with the return of the VO65 fleet, and Biotherm taking their first win after only arriving in Aarhus yesterday evening.
IMOCA Race Report
As the IMOCAs got under way just after 1400 local time, the sea breeze had built to nearly 10 knots, providing steady conditions for the fleet. The rectangular configuration race course was set at three laps.
As the clock counted down, the first decision for crews was focussed on the sail configuration. Judging whether the breeze had built to its peak or whether there was more to come was the key pre-start decision. After that, judging the time on distance approach into the start was critical.
Biotherm and Team Holcim-PRB were closest to the start line in the final moments and appeared to be struggling to kill their pace.
Meanwhile, having started their run from further back, 11th Hour Racing Team (USA) looked like they could maintain more of their momentum.
But as the gun went, it was Biotherm that timed their approach and building speed perfectly to hit the line at the leeward end at pace, gaining the initial advantage as the four boats made their way up the first leg.
By mark 1 Biotherm led with Team Holcim-PRB in second, 11th Hour Racing Team third and Team Malizia in fourth.
Leg 3 saw Biotherm stretch their lead over the fleet on the long reach back down towards the bottom of the course.
Biotherm only arrived in Aarhus late on Saturday night after a difficult and frustrating transatlantic leg, making their dominant performance all the more impressive.
Judging when to tack on leg 4 to lay the next mark was another key decision to ensure no distance was given away. Once again Biotherm picked the perfect spot and gained over the rest of the fleet as a result. On the second lap they had drawn out to 640m ahead of Holcim-PRB.
Towards the end of that lap Biotherm delivered another perfect rounding of marks 3 and 4 to extend their lead even further.
Behind them life wasn't easy. With a strong incentive to try to cut the distance to the upwind mark there was a temptation to tack too early. Team Holcim-PRB almost fell foul of this but got away with it, while Team Malizia did not and ended up squeezing up to the mark, losing more distance as a result.
On the final lap it was more of the same from Biotherm with a perfect performance stretching the lead even further to take the in-port win in Aarhus.
Meanwhile, 11th Hour Racing team took distance out of Holcim-PRB to the point that on the downwind leg at the top of the course, there was an opportunity for Charlie Enright's team to gain a place. But sailing low in an attempt to catch Holcim-PRB on the give-way port tack slowed their progress too much and gave away distance instead.
Team Holcim-PRB finished second, 11th Hour Racing Team third and Team Malizia fourth. "We won the start and when you win the start in an In-Port Race it's easy after," Paul Meilhat said after the race. "We were a bit faster off the line than Team Holcim-PRB and that was it. We are really happy and I dedicate this win to our shore team who have worked so hard to get us out here. It's our first victory so it means a lot to us."
"It's a first step for the new crew," said Team Holcim-PRB skipper Benjamin Schwartz. "We managed to get around the course nicely. We had a bit of tension when 11th Hour Racing Team came back on us a little bit, but the team did a great job to stay in front."
IMOCA - Aarhus In Port Race - Results
1. Biotherm - 5 points
2. Team Holcim-PRB - 4 points
3. 11th Hour Racing Team - 3 points
4. Team Malizia - 2 points
5. GUYOT environnement - Team Europe - 0 points
See the overall leaderboard for both fleets here
VO65 Race Report
Earlier in the day, it had been the VO65s who took to the race course first, in light winds of 5 to 7 knots as the sea breeze was only just getting established.
As the seconds counted down to the start, initially it was WindWhisper Racing Team (POL) that appeared to have the early momentum although a round-up manoeuvre at the pin end slowed them down. Instead, it was Team JAJO (NED) that got the best start delivering a perfect time-on-distance run into the middle of the start line.
A few minutes later WindWhisper had built their pace once again to pull themselves into the lead. By the first mark, WindWhisper led, followed by Team Jajo who rounded 16 seconds behind. In third place it was Viva México, closely followed by Mirpuri/Trifork Racing Team (DEN).
After a short reaching top leg it was a gybe at mark 2 for a longer broad reaching leg back down towards the start area.
So far the manoeuvres had been kind to the boat speed with bear aways and gybes helping to keep the speed on. Keeping momentum was critical.
Leg 4 was an upwind affair and it was here that crews came under a great deal more pressure to maintain their pace.
For WindWhisper a well timed approach and a slight gust provided a smooth mark rounding. The same was true for Team Jajo as the pair stretched their lead on the rest of the fleet.
When it came to the tack to reach mark four, both boats delivered perfect executions, helped by a slight increase in the breeze.
Meanwhile further back, there was a tight battle between third placed Viva México and Mirpuri/Trifork Racing Team as the pair duelled for mark 4 with less than a boat length between them.
The second lap of the course didn't provide any passing opportunities and skipper Pablo Arrarte's WindWhisper Racing Team held off Team JAJO for the win. It was a flawless performance and a great win for the Polish team as the VO65 Sprint reignites.
"It's been awesome to get back into the race," said WindWhisper skipper Pablo Arrarte. "We've been away from the race for a while, watching the IMOCAs, which has been great, but it's time to get back.
"We've had some changes on the crew but had an opportunity to train here for the last 10 days so we were confident we could handle all the situations today. It was a tricky day and the start was so important, but we managed okay and we got a good lead there and we were able to hold it."
VO65 Sprint - Aarhus In Port Race - Results
1. WindWhisper Racing - 6 points
2. Team JAJO - 5 points
3. Viva México - 4 points
4. Trifork Mirpuri Racing - 3 points
5. Austrian Ocean Racing / Team Genova - 2 points
6. Ambersail - did not start - 0 points
Bernardo Freitas to skipper Racing for the Planet
In the Mirpuri Foundation Sailing Trophy 2024 The Mirpuri Foundation Racing Team announces that former team watch captain Bernardo Freitas (POR) will lead the Team in the 2024 edition of The Mirpuri Foundation Sailing Trophy, in July. Posted on 9 May
The Mirpuri Foundation Sailing Trophy preview
A sustainable regatta that will see sailing boats take to the Atlantic coast of Portugal Organised in partnership with the Clube Naval de Cascais, the sustainable regatta will see a large number of sailing boats take to the Atlantic coast of Portugal, to raise awareness and important funds for marine conservation programs. Posted on 24 Apr
The Ocean Race will return to Genova
A key stopover for The Ocean Race Europe in 2025 The Italian city of Genova and The Ocean Race will extend their close relationship with The Ocean Race Europe bringing a fleet of foiling IMOCA race boats to the Mediterranean port in the late summer of 2025. Posted on 24 Apr
The Ocean Race joins world leaders in Athens
Nature's Baton and the Relay4Nature connect at Our Ocean Conference The Ocean Race joined world leaders at the Our Ocean Conference 2024 at the Stavros Niarchos Foundation Cultural Center (SNFCC) in Athens, Greece on Tuesday, who had gathered to advance measures to protect and restore ocean health. Posted on 17 Apr
The Ocean Race sails into Athens
For the Our Ocean Conference UN Secretary-General's Special Envoy for the Ocean hands Nature's Baton to Greece's Prime Minister's Special Envoy for Oceans and Coordinator of the conference. Posted on 15 Apr
The Ocean Race and IOC UNESCO collaborate
Contributing towards the science we need for the ocean we want In the lead up to the 2024 Ocean Decade Conference, The Ocean Race today shared the impact of the data collected by teams and sailors through the race's science on board programme. Posted on 9 Apr
The Ocean Race gathers critical polar ocean data
From Antarctica and the Northwest Passage The Ocean Race is providing critical data to international scientists studying the impact of climate change and plastic pollution on ocean health. Posted on 8 Apr
The Ocean Race Europe 2025 will start from Kiel
Aim is to combine this event with the topic of ocean health and protection Organisers of The Ocean Race have confirmed Kiel.Sailing.City as the host of the start of The Ocean Race Europe during a press conference in Kiel on Wednesday morning. Posted on 14 Feb
The Ocean Race ends an epic 2023 on a high note
An incredible race year comes to a close An incredible race year comes to a close with the Notice of Race released for The Ocean Race Europe in 2025 and The Ocean Race 2026-27 along with comprehensive reports on the 2023 event... Posted on 21 Dec 2023
The Ocean Race wins the Sustainability Award
In the International Sports Awards 2023 The Ocean Race, the toughest and longest test of a team in sport, has taken the top prize in the Sustainability category of the 2023 International Sports Awards, hosted by the International Sports Convention. Posted on 7 Dec 2023
