Convenient hardware speeds fender hanging
by Accon Marine 13 Sep 2022 03:49 UTC
Tying off lines to position fenders before arriving at the dock can be a repetitive and time-consuming chore, particularly when boating solo. Series 401 Quick Release Fender Hangers from Accon Marine make bumper deployment and stowing a snap.
Formed from ultra-durable 316 stainless steel for long life and extreme corrosion resistance, Series 401 Quick Release Fender Hangers utilize a convenient two-piece design. This enables organizing of lines ahead of time, then quickly snapping them in place for rapid bumper deployment at a consistent length.
The surface-mounted base measures a mere 91mm L x 30mm W and installs with two #10 stainless screws. Each fender line attaches to a separate steel ring pin, which plugs into the base with a gentle push when bumpers are needed. Upon leaving the dock, sliding a small tab on the base releases the entire setup for quick storage.
Accon Marine Quick Release Fender Hangers come in two sizes: the 401-R-.5 with a 13mm ring diameter; and the 401-R-1 with a 25mm diameter. Both models stand under 51mm H with the ring pin in place to minimize deck clutter.
For more information visit www.acconmarine.com.
