Bembridge Sailing Club Redwing & One-Design Weekend Racing - early July
by Mike Samuelson 4 Jul 2022 08:59 UTC 2-3 July 2022
Early afternoon on Saturday, seven Redwings made their way to Drum where the Race Officers had set up an inshore windward inflatable in an attempt to find some protection from the SSW'erly F5 breeze. Despite best intentions it was still quite choppy, but at least they tried!
The start was certainly quite exciting with the bow of Gosling, helmed by Serena with Jonathan & Sarah Nainby-Luxmoore as crew, inches from the stern of Red Gauntlet II, helmed by Joe Robertson with his mother Annie crewing.
After a very short beat to the inflatable, Joe rounded ahead of Colin Samuelson in Toucan with Gosling just in front of Quintessence helmed by Robin Ebsworth. It was by no means a 'follow my leader' on the run to Derek and the subsequent long beat back to the windward inflatable. Toucan, three up had edged into the lead by then; but Joe, two up, did very well to hold off Gosling. The second run and beat back to the line saw no changes to the order with Toucan crossing the line 30 seconds ahead of Red Gauntlet II; Gosling was third a minute later and Paroquet, helmed by Rory Morrison was fourth twenty seconds later.
With the breeze remaining around 20 knots, Toucan decided to head back to the harbour, leaving the other six boats to start a second race. It was a similar course but with the finish moved to Pepe as everyone was returning to the harbour overnight. After a good start, first to the inflatable windward mark was Paroquet, with Gosling and Red Gauntlet II a couple of boat lengths behind.
By the time they had completed the first round, the fleet had split in half, with the front three close, then a gap and then the back three close. All found it quite difficult to get on the lay line to round Drum as the breeze was flicking 15 degrees and most overstood. Although the final beat from Derek to Pepe via Drum was as challenging as always, Rory held his nerve and finished a minute and a half ahead of Serena with Joe third, 20 seconds later. Henry & Rod Thorpe in Redwitch had closed the gap a bit to take fourth with Quintessence fifth and Alastair Speare-Cole in Avocet not far behind.
Meanwhile, for the first One-Design race there were only two takers; Susie & Sid Beart in No 5 and Charles & Lavinia Perry in No 8. Both boats had rigged storm sails and after a short postponement while No 8 sorted out their jib, they followed the same course as the Redwings, albeit only once round. Charles was first over the start line but Susie tacked off quite quickly which paid in spades and put her well ahead at the inflatable windward mark. She maintained her lead for the rest of the race and finished a minute ahead.
By the time the second race started, No 6 helmed by Ashley McLucas, had joined the fray. The start was closer and even though No 6 had normal sails and was three up, Susie was again first round the windward inflatable followed a few boats behind by Charles.
On the beat in from Derek to the finish at Pepe, No 8 was trailing last until the last 200 metres when they got a favourable lift and all of a sudden moved into the lead. No 6 was second to finish a few seconds later with No 5 a similar distance third. However No 6 subsequently retired when it was pointed out that they had been using the wrong sails!
If the sun had been shining a bit more on Sunday afternoon, it would have qualified as 'champagne conditions'; as it was, the SW'erly Force 4 and intermittent sunshine definitely qualified as 'prosecco sailing'! Eight Redwings were set a simple windward-leeward course starting from Footprint with Pepe as the windward mark and Ruthven as the leeward mark - twice round finishing at Pepe.
Sadly there is no video of the start as the Race Officer (Mike) failed to press the video record button! Pity as it was a one of the best this season. Toucan and Plover nearly came to blows in the final few seconds, however the latter subsequently did her penalty turn before setting off to catch the rest of the fleet up.
The first beat to Pepe saw split tacks with Paroquet rounding just ahead of Toucan and Red Gauntlet II. On the long run to Ruthven, the front three initially looked as if they were having trouble locating the mark, but subsequently assured the author it was merely tactical sailing! Suffice to say that by the time they reached the mark, the chasing fleet had narrowed the gap! First round was Red Gauntlet II with Toucan and Paroquet close behind. Sea conditions offshore were surprisingly confused so it was interesting that all bar Redwitch kept out on port tack until they got closer to St Helens Fort.
Red Gauntlet II held onto her narrow lead and rounded Pepe for the second time just ahead of Toucan with Paroquet, Plover, Redwitch, Gosling, Snowgoose and Quintessence spread out behind. Red Gauntlet II was still just ahead on the second run to Ruthven, but on the beat to the finish as Pepe, Toucan took advantage of a couple of favourable wind shifts that put them half a minute ahead at the finish; Plover also had a good final leg and took third ahead of Paroquet, Gosling, Redwitch, Snowgoose and Quintessence. There were no One-Designs.
After an excellent couple of days racing, Joe Robertson in Red Gauntlet II won the Fortuna 1950 Medal.
Ten o'clock starts next week - Redwings for the Curlew Cup and the One-Designs towards their Off Season Points.
Redwing Quail Trophy & One-Design Woodroffe Bowl
Early starts for the Bembridge Keelboats over the early May Bank Holiday Although the tides required early starts (09:30/09:40), the weather, certainly on Saturday provided some great sailing for both the Redwings and One-Designs; the former their first weekend of the new season and a continuation of the latter's season. Posted on 6 May
Bembridge Illusion season comes to a close
With the St George's Day Trophy and the Woodford Long Distance Race Not the kindest weather for the final weekend of the Illusion season, however it could have been worse and at least the drizzle on Saturday held off until the finish of the last of the four races for the St George's Day Trophy. Posted on 29 Apr
Bembridge One-Design April Racing
An early start on Saturday for the fleet It was an early start on Saturday due to a 10.30 high tide, and five One-Designs tacked out of Bembridge Harbour into a chilly 15kts from the NNE. A start line was laid at Footprint with Britten set as a windward mark, then a run to Garland. Posted on 23 Apr
Bembridge Illusion Designer Trophy 2024
Racing for the drawing of Jo Richards' original concept drawing of the Illusion At the end of the 40th Anniversary dinner in December 2022, Jo Richards, the designer of the Illusion generously presented the Class with a drawing of his original concept for an enlarged single handed model yacht which was foot steered. Posted on 22 Apr
Bembridge Illusion Flying Dutchman Trophy
A challenging weekend thanks to Storm Kathleen Storm Kathleen, early starts and being the weekend after Easter all contributed to lower than normal numbers racing for the Flying Dutchman trophy. Posted on 7 Apr
Bembridge One-Design Oppenheim Trophy
Ten One-Designs back in the water for the 2024 summer season With ten One-Designs back in the water for the 2024 summer season it was perhaps a bit disappointing that only two boats rigged up for the opening races on Good Friday. Posted on 2 Apr
Bembridge Illusion Vernon's Easter Egg Cup 2024
Battling gale warnings, icy rain and cancelled ferries Gale warnings, icy rain and cancelled ferries on Maundy Thursday was enough to put off some of the hardy Illusion fleet helms from sailing the first day of Vernon's Easter Egg Cup on Good Friday. Posted on 31 Mar
Bembridge Illusion Spring Plate 2024
Fourteen boats rigged up to race on Saturday Fourteen boats rigged up to race on Saturday, however sadly Tim Lyle had a problem with his steering and never left the pontoon but the other thirteen eventually got their acts together and made it to Sea Breeze located to the north of the Redwing Quay. Posted on 25 Mar
Illusion Prince Philip Memorial Trophy 2024
Forecast and early tides kept a number of competitors away First raced for in April 2021 in memory of the late HRH The Duke of Edinburgh, this year's running of the Prince Philip Memorial Trophy disappointingly only saw seven entries competing for the Trophy. Posted on 11 Mar
Bembridge Illusion Bill's Barrel 2024
Almost perfect conditions after a week of rain and strong winds After another three days of rain and strong winds, it was a relief that Saturday afternoon's SW'erly F3 breeze with sunny patches proved to be almost perfect for the fifteen Illusionists who launched ready for this year's 'Bill's Barrel' weekend. Posted on 4 Mar
