Learn to love sailing in heavy air
by North Sails 21 Dec 2021 13:16 UTC
2017 Melges 20 World League © Barracuda Communications
When I was about ten years old I starting racing sailboats on Cape Cod and the sound of the wind whistling overnight through the pine trees outside my bedroom would make it hard to sleep. Even the next morning I'd have a knot in my stomach when I woke.
Forty years later, I still get the knot in my stomach with just the thought of sailing in heavy air but luckily, I've learned more about the technique and in turn, have become more confident when it comes to heavy air sailing. If sailing in a strong breeze intimidates you, you are not alone, but you can learn to get better at it and actually start to dominate in the breeze. Here are some tips to help shake your nerves and get you confident for that next heavy air event.
Wear a lifejacket
Seems pretty basic, but there was a day when wearing a lifejacket was not as prevalent as it is now. As soon as the breeze comes up, put one on yourself and make it mandatory that your crew do the same. It will give you more confidence to be more aggressive in moving around on deck and when trimming/pumping your sails. And it's the right thing to do.
Know your settings
Once you are out on the water and it starts blowing, there is no time to be figuring out how many turns to go up on the rig. Be sure to pre-measure your rig tension and know how many turns it takes to get to your heavy air settings for each wind speed.
Setup your boat so it's easy
In all boats, flat is fast in breeze. It's also important to keep the boat on an even angle of heel. If the boat is constantly heeling over you tend to use more rudder which creates drag, which will eventually cause the boat to stall out head to wind. Concepts to keep in mind:
  • Set Up for Twist. Tight leeches on the main and jib will make the boat more sensitive to tipping over each time you get a puff. To induce twist:
    • Sail with the backstay VERY firm
    • Ease the main and jib (simultaneously)
    • Vang on hard if effective on your boat. This will flatten the lower portion of the main and open the lower leech
    • Play the sails. Play the main especially to keep the boat on an even angle of heel. The smaller the boat the more you play your sheets.
    • Keep the traveller on or slightly above the centerline.
  • Try not to Hit Waves Dead-on. If you do, at least make sure the boat is flat. Back when I learned to sail the mantra with steering in waves was to "head up the face of the wave and bear off on the backside of it. Today we use as little rudder as possible to steer around the big sets. Inevitably, you will hit waves, and some straight on. When you do, be sure your boat is flat. The boat will stop, but if it is flat it will not slip sideways as much.
  • Have fun. Sailing in heavy air is exhilarating. Enjoy the process of getting better each time you go out in a breeze!
Find out more at NorthSails.com
Why are 3Di sails aero-optimized?
A streamlined sail shape delivers less drag, more drive, and greater effectiveness North Sails explain the advantages of aero-optimisation: a streamlined sail shape delivers less drag, more drive, greater effectiveness and enhanced durability. Posted on 2 May
Top North Sails designer dead at 47yrs
Leading North Sails designer Gautier Sergent passed away after sustaining a heart attack It is with immense sadness that we share the news that our friend and North Sails colleague Gautier Sergent passed away after sustaining a heart attack. Posted on 27 Mar
Tony Rey is joining North Sails
New hire, Tony Rey has been part of three America's Cup campaigns and multiple Olympic campaigns Few sailors have such a diverse career and broad enthusiasm for racing and cruising. Tony Rey has been part of three America's Cup campaigns (2000, 2003 and 2007), he did multiple Olympic campaigns and was a coach for the 2004 US Olympic team. Posted on 19 Mar
Tom Davis on the North Sails' new cruising sails
A Q&A with Tom Davis about the North Sails' newest cruising cloth Sail-World checked in with Tom Davis, North Sails' commercial director, to learn more about RENEW, the company's newest and most sustainable panel laminate cruising sailcloth. Posted on 5 Mar
ARKEA Ultim Challenge Winner | TEAM GITANA
Maxi Edmund de Rothchild trusted North 3Di to power their circumnavigation The open ocean is unforgiving and unpredictable and Maxi Edmund de Rothchild trusted North 3Di to power their circumnavigation. These sails drove Charles straight across the finish line with more speed and power than the competition. Posted on 28 Feb
North Sails Launches Sustainable Sailcloth
RENEW laminate is for cruising boats 25 to 45 ft North Sails today launched RENEW, a North Paneled Laminate (NPL) sailcloth for cruising boats 25 to 45 ft. RENEW sailcloth is constructed from more than 90% sustainable sources, with no sacrifice in performance or longevity. Posted on 23 Jan
RSHYR 2023 | Bow Caddy Media Dockside Videos
Quayside with Bow Caddy media ahead of the 2023 Sydney to Hobart Yacht Race Quayside with Bow Caddy media ahead of the 2023 Sydney to Hobart Yacht Race Posted on 25 Dec 2023
RSHYR 2023 | Chris Lewis – Navigator - LawConnect
Chris Lewis explains the unusual challenges of weather routing for the 2023 Rolex Sydney Hobart Race Chris Lewis, navigator aboard LawConnect, explains the unusual challenges of weather routing for the 2023 Rolex Sydney Hobart Race when the various wind models remain so divergent, only two days prior to the start. Posted on 25 Dec 2023
RSHYR 2023 | Tony Mutter – Skipper of LawConnect
“I think we need to take a bit of a look at ourselves and stop doing that!” “I think we need to take a bit of a look at ourselves and stop doing that!” said Tony Mutter – skipper of LawConnect - referring to all of the Hobart navigators and skippers who've been constantly checking a highly dynamic weather pattern for days... Posted on 24 Dec 2023
Introduction to Campaign Essentials - Part II
What qualities are you looking for in a pro on an amateur team? When preparing for an offshore sailing campaign, how do you best go about selecting crew and what qualities are you looking for in a pro on an amateur team? Posted on 24 Dec 2023
