Cleaning while fishing is easy with the Shurhold System
by Shurhold Industries 2 Aug 2020 05:24 UTC
Telescoping Handles © Shurhold
When you're fishing, things can get a bit messy (or at least they should!). Chunks of bait, coagulated blood, spilled drinks, etc can all quickly stain your non-skid, hull, and vinyl padding.
If you let these messes sit too long, your cleanup at the dock will go from a quick rinse down to a timely ordeal! Don't let that happen by employing a few easy tips that make cleanup easier.
Hose Nozzle
$11.98
This ergonomically-shaped, die-cast zinc hose nozzle has a soft, black, vinyl grip for a comfortable hold. Adjustable flow and spray. Also included is a standard screw-in house quick connect end that works with most quick connect systems
Telescoping Handles
$34.98 - $44.98
The One-Handle-That-Does-It-All! Our handles are made with triple anodized aluminum and are compatible with more than 40 different attachments. These models are telescopic for easy storage or adjusting to the perfect length.
