Bow down and send it!
by Ian Dobson, with foreword by Andy B Robinson 24 Apr 2020 13:30 UTC
Ian Dobson and crew Richard Wagstaff winning the 2019 Worlds in Canada © Urs Hardi
Ian Dobson is the current World and National Champion in the Fireball Class. In the following article, originally published in edition 8 of the Fireball E-News, he explains the mystical 'fast mode'.
The fast mode is an upwind 'second gear' that the gold Fleet seem to be able to find and utilise to drive upwind speed and height. As the Silver and Bronze fleet sailors don't quite understand what it is or where to find it, we asked Ian to explain...
What does that even mean?
Often referred to by many in the bar after a big day on the water, but frequently overused, misused or abused. So let's discuss in more detail about generating a fast [and high] mode sailing in a straight line upwind in more than, say, 14knts of wind. For simplicity, let's not focus on wind speeds of more than 22knts.
Firstly, the 'Fast Mode' is about improving velocity made good (VMG) not about reaching off to the cliffs. This comes from constantly playing between height and speed. One of the key aims could be to promote planing, which is what the knife edge terminology alludes to. In reality a Fireball sails in a 'semi-planing mode' and the aim is simply to increase boat speed through the water and reduce displacement drag without giving away too much height. The term "Bow Down" is too coarse a measure, and I would refrain from using it. Instead I like to say 'leaning on the jib' as I feel this communicates the level of subtlety and precision that is required. A measure for this could be instead of sailing with your lowest windward jib telltale lifting at an angle of 20 degrees to the horizontal, perhaps they might be between 10 degrees and horizontal. Generally speaking, a 'horizontal telltale mode' is only used to accelerate the boat, and therefore should only be maintained for a few seconds until a new steady velocity is achieved, from there we need to refocus our efforts on not giving away distance to windward. Do this by pulling the main sheet in, using the leach to arc the boat back upwind. When the boat is really trucking, this arc can be stretched out. We lean on the jib again at the point at which the boat starts to decelerate.
Next, 'leaning on the jib' is actually not high on the priority list. In fact, it is probably quite low down, as it is merely a tool to accelerate the boat. The priority is ALWAYS on sailing the boat flat, sailing the boat precisely and consistently on the wind, and maximising our leverage to enable us to maximise our power conversion (trapezing flat, hiking hard).
Boat set-up is crucial to achieving a flat and stable platform for the helm to achieve the above. The narrow rig base makes the Fireball mast quite bendy. Combined with a large mainsail it is almost impossible to use too much kicker [in breezy conditions, notwithstanding lull response]. Kicker pushes the bow upwind and makes us point higher as well as flattening the mainsail to reduce drag. For information, I cannot physically pull more kicker on upwind in more than 20knts. There probably is a mode to be had by easing the kicker (and strut) but I can't say I have found it. The jib slot should match the mainsail, but often this is controlled by mast rake rather than jib bars, lift the bars to fine tune or if you are caught on the wrong mast rake. Easing the jib to help accelerate the boat is sometimes ok - but note that 10mm out on sheet is the correct sort of range. Do squeeze it back in when the boat is moving fast.
What does it feel like? Easy - Like warm apple pie!
A fireball is a lovely boat to sail upwind in breezy conditions. Sailed well, a fireball is able to generate speed and height. Fireballs are fortunate to have an efficient centreboard section, which, once higher water flow velocities are achieved, generates a high lift to drag ratio. Lifting the centreboard increases the chord length and reduces the camber to chord length ratio, which, at higher Reynolds numbers (faster speeds), produces a more efficient section. It also keeps you more steady in a straight line. What does that mean? Once you are going quick, you can also go high. Lifting the C/B also has a second effect - it frees the bow. This is to say that moving the centre or resistance (lift) backwards reduces weather helm (tiller tug) and naturally makes us lean on the jib. This is another reason why you should not [over]actively put the bow down! Lift the C/B too far and you will lose the bow and generate lee helm. Aim for very small amounts of weather helm. Typically the centreboard will go from vertical up to 1-2 inches up as we start to free to bow. Reserve the numbers 3-4 for when its really blowing and never [save for survival] go more than 5 inches up. The fireball really starts to sing when you generate speed and turn it in to height, it becomes easy to sail, the rudder is balanced and light and mainsheet movements become smaller as you use the main leach to generate height. It will practically sail itself!
Key points - Keep the range of steering angles narrow and don't give away too much height. Balance the boat and let it sail the angle - using loads of kicker, sneaking the board up to neutralise the load in the tiller and always sailing flat. Work hard to accelerate the boat, using a short sharp mainsail ease to 'lean on the jib', use the main leach to drive the height again and then chill out at Mach 10 and let the good times roll!
Fireball Spring Championship at Hayling
Inaugural event remembers a well liked sailor who tragically died in a plane crash The inaugural Spring championship took place over the weekend. A trophy has been presented by Ian Castle who is the class treasure and farther of Tom Castle - a well known and liked Fireball sailor who tragically died in a plane crash a few years back. Posted on 14 May
100 Years of Jack Chippendale
One of the greats behind the golden era of the UK's domestic dinghy scene Regular readers will hopefully have enjoyed the recent 'Fine Lines' series of photos, times to coincide with the centenary of one of the greats behind the golden era of the UK's domestic dinghy scene, Jack Chippendale. Posted on 13 May
'Fine Lines' Top Ten part 10
With a full history of master boatbuilder Jack Chippendale This, the tenth and final Fine Lines in this series ends up with a real example of what the thinking is all about, that near perfect fusion of style and function. Plus a more detailed look at Jack's life and his boats. Posted on 1 May
Fireball Spring Championship Preview
The fleet is looking forward to classic Hayling Bay racing HISC is hosting the Fireball Spring Championship on 11/12 May. We're looking forward to 6 classic races out in Hayling Bay. Posted on 1 May
Irish Fireball Munster Championships
Stunning conditions at Monkstown Bay Sailing Club The Irish Fireball Munster Championships were held last weekend on April 20th/21st at Monkstown Bay Sailing Club in stunning weather conditions. Posted on 25 Apr
The oldest video footage of Fireball dinghies
A look back into our video archive We delve into the past, and round-up all videos which show sailing in the Fireball class of dinghy. Posted on 21 Apr
Viking Marine DMYC Frostbites series 2 overall
Final races run in contrasting winds The last Sunday of the Viking Marine sponsored Frostbites arrived with a forecast of contrasting conditions, blustery winds for the morning, followed by winds of between 5 and 7 knots during the projected race time with a 90 degrees swing. Posted on 27 Mar
Viking Marine DMYC Frostbites series 2 day 17
Increasing wind strength reduces St Patrick's Day sailing to a single race The St Patrick's Day Frostbites saw the lowest turnout of boats in Series 2 thus far - maybe just the weather forecast for the day which showed the early part of the afternoon to be manageable, but getting heavier later on. Posted on 21 Mar
Viking Marine DMYC Frostbites series 2 day 16
Another two races in the bag, in Dun Laoghaire Despite a horrible forecast of wind which caused Howth's Round the Island Race to be cancelled (on the Saturday) and huge seas in Dun Laoghaire on Saturday, the dinghy Frostbites, sponsored by Viking Marine took place on Sunday afternoon. Posted on 12 Mar
Viking Marine DMYC Frostbites series 2 day 15
Weather permits three races, at last! After a week that saw snow fall over large parts of Dublin and further afield on Friday, Sunday was, by comparison, a pleasant spring day with sunshine and a gentler breeze that the previous Sunday. Posted on 5 Mar
