Ajax National Championship at Royal Harwich Yacht Club
by Mike Clayton 24 Sep 2019 11:52 UTC 19-22 September 2019
Polly Oliver and Mandalay during the Ajax National in Dovercourt Bay © Will Patten
The defending champions from St Mawes joined nine local boats for the eight race series sailed in Dovercourt Bay, Harwich. The St Mawes crew chartered Mandalay, one of the three Ajax's donated to the Royal Harwich Yacht Club earlier in the year.
Day 1
The fleet enjoyed three competitive races in Dovercourt Bay. Race Officer Graham Louth set windward leeward courses for the first two races and a triangle-sausage for race 3.
The first race started in an ESE F3 and Polly Oliver (Mike Clayton, Bob Portway, John Gill), Mandalay (Paul Scullion, Ian Woods, Jack Elsby-Hartman) and Thunderer (John Williams, Hugh Williams, James Williams) got the best starts. All three arrived at the windward mark close together with Polly Oliver on the inside and Mandalay on the outside. The outer boats benefitted and Mandalay led down the run with Thunderer and Polly Oliver close behind. On the second beat Mandalay and Thunderer found more wind and extended away to the finish. Behind the front three Orwell VI (Richard Merriweather, Mark Ingram, Simon Abley) pulled through to secure fourth.
In the second race Polly Oliver started well at the pin end with Mandalay mid line. These two quickly established a lead with Mandalay again finding a faster lane to the windward mark. Thunderer pulled through on the run to challenge Polly Oliver. On the second beat Polly Oliver found the best shifts to lead at the windward mark and held on to win with Mandalay second and Thunderer third.
After a short pause to adjust the course to the wind shifting to the East, the third race started with Polly Oliver again getting the best start at the pin end. She pulled away up the beat with Orwell VI close behind and Mandalay recovering from a poor start getting to the first mark third. Behind these three Pegasus (Belinda Joslin, Sian Goodman, Steph Hensley) was going well and moved ahead of Thunderer. Polly Oliver stayed ahead for the first lap but on the second beat Orwell VI found some good shifts to lead with Mandalay closing. At the windward mark Mandalay was able to squeeze round while a boat length behind Orwell VI held off Polly Oliver to round second. These positions remain unchanged on the final run and short beat to the finish.
Leading Overall (after day 1). Mandalay (Paul Scullion) 1,2,1; Polly Oliver (Mike Clayton) 3,1,3; Orwell VI (Richard Merriweather) 4,4,2; Thunderer (John Williams) 2,3,5.
Day 2
This was another sunny day with good winds on the East Coast - A solid F4 gusting F5 for the first race blowing from the ESE. The sea looked a lovely shade of brown as sand was blown in from the Cork Sands. The 4th race started with some pin end bias with Polly Oliver and Orwell VI at the pin end. These two pulled away and Orwell VI tacked off and cleared the rest of the fleet including Mandalay and Thunderer. For these four the approach to the windward mark was going to be key and Orwell VI judged the lay line to perfection allowing the initial flood to push her up and round first, followed by Mandalay, Telamon (Gordon Sutton, Mike Moore, Phil Codling) and Polly Oliver. Orwell VI and Polly Oliver gybed early and went round the leeward mark first and second. On the next beat Orwell VI extended away whilst both Mandalay and Telamon caught Polly Oliver.
For Race 5 the course was reset and the line was biased towards the Committee Boat. Polly Oliver started at that end and tacked onto port early. Orwell VI again was going much faster than everyone else and led round the first mark for a comfortable win. Behind, Polly Oliver and Thunderer had a dual on the run with Polly Oliver managing to surf ahead. Mandalay recovered from a disastrous first beat to finish 4th.
Finally Race 6, a triangle sausage. Orwell VI with two race wins for the day was buried at the start with Mandalay and Polly Oliver clear at the committee boat end. Mandalay went right and Polly Oliver left. At the windward mark Polly Oliver rounded with a narrow lead from Mandalay with Telamon and Thunderer close together behind them. On the second beat Mandalay again went right and pulled ahead for the win with Polly Oliver a comfortable second. Behind Orwell VI had recovered and managed to split Thunderer and Telamon with Telamon gaining their second third place of the day.
The day belonged to Orwell VI, but Mandalay did enough to stay 4 points clear of Polly Oliver, with Orwell VI 1 point behind in third.
Day 3
With a forecast of F2 toF3 and initially sunny skies the fleet set off from Shotley for the final two races of the series. Race Officer Graham Louth set windward leeward courses for the last two races, but in Dovercourt Bay the wind gradually dropped to around 8 knots for the start of the seventh championship race. Two boats including Orwell VI were OCS and Mandalay and Polly Oliver both had good starts. After returning Orwell Vi went right and gained significantly, whilst Guillemot David Mayne, Kelvin Douglas, David Pearce), Pegasus and Thunderer all sailed good beats. At the windward mark Mandalay rounded first, followed by Orwell Vi, Guillemot and Pegasus. Thunderer failed to round the mark and needed to do turns. On the run Polly Oliver gybed early and passed Pegasus, the other places remained unchanged. The main change on the second beat was Pegasus regaining fourth by passing Polly Oliver. At the finish Mandalay had a comfortable lead, with Orwell Vi, Guillemot and Pegasus finishing close together. This was enough to give Mandalay the championships with a race to spare.
For the final race the course was shifted following a wind shift to the right. At the start Polly Oliver was OCS (already halfway round the Committee Boat) whilst Orwell VI and Mandalay and Thunderer all had good starts. A number of boats, including Mandalay, Orwell VI and Telamon went right with Thunderer, Guillemot, Dionysius and Polly Oliver going left. Those that went right lost out as the wind faded with Thunderer reaching the windward mark first, closely followed by Dionysius and Polly Oliver. On a slow run Thunderer and Polly Oliver gybed and headed inshore and established a gap on the boats behind. Guillemot and Pegasus passed Dionysius and the whole fleet were hearted when the Race Officer shortened the course to one 45 minute lap.
Congratulations to Paul Scullion, Ian Woods and Jack Elsby-Hartmen for a well deserved win against a competitive East Coast fleet. The top four boats all won races and there was competitive racing through the fleet.
Thanks to the race team of Graham Louth, Caroline Louth and Peter Wright and Support Boat Crews Will Patten, Joe Hunt, Paul Wright, Charles Twiss, Mark Freeman and Jack Moore.
Overall Results:
If you took part in the Ajax nationals then enter your Gear Guide information here
PosBoatSail NoHelmR1R2R3R4R5R6R7R8Pts
1stMandalay50Paul Scullion1212411‑912
2ndPolly Oliver17Mike Clayton313422‑5217
3rdOrwell VI57Richard Merriweather4421142(DNF)18
4thThunderer14John Williams235535‑7124
5thPegasus29Belinda Joslin57466(DNC)4436
6thTelamon61Gordon Sutton767353‑10738
7thGuillemot20David Mayne856(DNC)DNCDNC3347
8thTeal26Bob Tate‑9887768650
9thDionysius71Phil Mayhew109988(DNF)6555
10thPrometheus62Tim Archer6‑10109979858
Ajax Nationals at St Mawes
A competitive fleet of boats at the stunning venue A great fleet assembled in St Mawes, including the travelling duo of Orwell VI and Dionyssius who had made the long trek down from the east coast, to experience clear blue seas, crystal clear skies, a comparative lack of container ships. Posted on 9 Aug 2023
Ajax East Coast Championship
Eleven boats sailed from Royal Harwich Yacht Club Eleven boats sailed the Ajax class East Coast Championship on 23rd to 25th June organised by the Royal Harwich Yacht Club. Posted on 27 Jun 2023
Ajax class at the Falmouth Week Regatta 2022
Sun hats obligatory, patience required, and swimming recommended Twelve Ajax class yachts competed at the Falmouth Week Regatta 2022 in the Carrick Roads. With a very substantial high pressure located over most of the UK, the forecast for the week was very light, with sun hats obligatory and patience required. Posted on 15 Aug 2022
Ajax South West Championship at St. Mawes
Thirteen teams enjoy battles in Falmouth Bay The class had agreed a 1-hour postponement the day before as the forecasted breeze was negligible in the morning so we all headed out for a noon start to the first race. Race Officer, Neil Andrew, managed to get the champs off to a good start. Posted on 1 Aug 2022
2022 Ajax Nationals at Royal Harwich Yacht Club
Great race management in varied and sometimes awkward conditions Sadly there were no visitors from the South West Fleet despite early enthusiasm. The whole series was spent on flooding tides, and working out the different streams across the courses seemed to be quite important! Posted on 7 Jul 2022
Falmouth Sailing Week preview
From Mirror dinghies through to IRC 1 rated yachts The highlight in the racing calendar each August has to be Falmouth Sailing Week. This year is planned to be bigger and better for those wanting to try out their Mirror dinghy through to IRC 1 rated yachts. Posted on 11 Jun 2022
Ajax class at Falmouth Week
One knitting pattern of a course that would have baffled Tom Daley Westerly breeze that varied between F3 and F5 led to an interesting conundrum for the race officer with an ever-increasing incoming southerly spring tide, the result was a knitting pattern of a course that would have baffled Tom Daley. Posted on 17 Aug 2021
Ajax Nationals at St. Mawes
A breezy start to the event as Storm Evert barrelled up the north Cornwall coast The morning of Friday July 30th was somewhat inclement, Storm Evert was barrelling up the north Cornwall coast and the wise decision from the race officer was to postpone for 3 hours before setting out into the bay. Posted on 5 Aug 2021
Ajax East Coast Championship at Royal Harwich
Four different race winners in the 5 race series Thirteen boats entered the 2021 East Coast Championships for the class sailed in Dovercourt Bay on the 17th and 18th of July. The weekend had light winds and sunshine and over the five race series there were 4 different race winners. Posted on 22 Jul 2021
Ajax class at Falmouth Week 2019
An incredibly testing week with big breeze and unstable winds An incredibly testing week with big breeze and unstable winds meaning very hard work for helms and crews alike. Posted on 19 Aug 2019
