Pop-up LED lights enhance any boat's style and safety
by Martin Flory Group 16 Jun 2018 02:29 UTC
Accon Marine's 210-M LED Bowlight model (top) and 211-M model © Martin Flory Group
Modern boat designs emphasize smooth flowing lines and an ultra-clean profile. Pop-Up® LED Bow Lights from Accon Marine retract flush into the deck to preserve a boat's good looks, while providing the dependability of LED construction for a USCG-approved range of 2 nm.
The only Pop-Up LED bow lights on the market, the 210-M and 211-M from Accon Marine are constructed from durable marine-grade 316 stainless steel for exceptional corrosion resistance. Both are NMMA type accepted and meet 72 Colregs requirements.
The 210-M offers a compact 109mm L x 102mm W footprint and installs easily, requiring only a drill with a 89mm hole saw and three #10 stainless steel screws. A stud-mount version, model 210-MS, has no visible screw heads.
With its 135mm L x 89mm W base, the Accon 211-M Pop-Up Bow Light fits the same cut-out hole as the company's non-LED 204-M model for an easy, direct upgrade. It's also available in a stud-mount configuration.
Optional waterproofing cups for Accon Marine lights prevent runoff below deck. Both the 210-M and 211-M Pop-Up LED Bow Lights enhance the style and safety of any boat with their flush-deck design and extended USCG range.
