Pop-Up stainless Bow Light melds style and function
by Martin Flory Group 22 Feb 2018 21:02 UTC
204 Pop-Up® Combination Bow Light © Martin Flory Group
While running lights are required onboard, their knobby appearance can detract from a vessel's flowing lines. The 204 Pop-Up® Combination Bow Light from Accon Marine retracts flush into the deck when not in use, preserving a boat's clean look while protecting the lamp itself from harm.
This stylish light combines port and starboard lamps for bow mounting, available in either standard screw-mount or stud-mount styles. Its 316 marine grade stainless steel construction ensures a long service life. A #78 bulb provides USCG-approved visibility of 1 nautical mile, and is readily available for easy replacement when needed.
The Accon Marine Pop-Up series also includes port, starboard and side lights. All are NMMA type-accepted and Colregs 72-compliant. Each is supplied with a cut-out template for easy installation, while optional drain cups are also available.
For more information contact Accon Marine, Tel: +1-727-572-9202; Fax: +1-727-572-7621or visit www.acconmarine.com.
