Retractable Cleats serve both mooring, lifting tasks
by Martin Flory Group 23 Jan 2018 03:29 UTC
Retractable 209 Series Mooring Cleats from Accon Marine © Martin Flory Group
Whether used for tying up for the night or hauling for launch, cleats need to perform without fail. Retractable 209 Series Mooring Cleats from Accon Marine are made from marine-grade 316 stainless steel for extreme durability, and can double as lifting hardware to preserve space.
The Accon 209 Series pull-up cleats offer the convenience and safety of recessing flush to the deck when not needed. They feature a sealed base with an integral drainage fitting, eliminating the need for a separate waterproofing cup and greatly simplifying installation. Each is shipped with a backing plate, which also serves as the cut-out template. These mooring cleats come in 114mm and 152mm sizes, as well as 203mm and 254mm.
To enable this versatile hardware to pull double-duty, Accon offers the 152mm through 254mm models as lifting cleats by adding a 305mm long threaded rod shank, sling, cross bar and bow eye. The maximum working load is 1,814kg in the direction of the axis of the threaded rod shank only.
For more information contact Accon Marine, Tel: +1-727-572-9202; Fax: +1-727-572-7621 or visit website: www.acconmarine.com.
