Sea Sure Dinghy Show Weekend Offers
by Daniel Henderson, Sea Sure 26 Feb 2021 08:30 UTC
Sea Sure Dinghy Show Weekend Offers: Red performance range fittings © Sea Sure
We are running 15% off across the whole site (www.sea-sure.co.uk) until 5pm on the 1st March when you use the discount code "DINGHYSHOW21" at checkout.
Offers include our new Red performance range fittings that give you the ability to change the pintle pin without removing the whole fitting from the boat. Check out the video if you missed it:
Our "FLO" tell tales have proved a massive hit amongst the sailmakers and sailors across Europe due to their 3M backing and improved sensitivity. As the Aerofoiled FLO holds the tell tale off the sail it also prevents them from sticking to the sail when its raining or after a capsize.
A 6 pack is available during the dinghy show weekend for only £13.60 - see www.sea-sure.co.uk/flo-tell-tales-6-pack-1362-p.asp?v=0&variantid=1363
PAD-I has been designed to allow you to fix low loading parts to your boat/deck without having to drill attachment holes. PAD-I has been manufactured using carbon filled nylon so it is extremely strong. It comes complete with a length of 1.5mm SK99 Dyneema which means that the whole unit only weight 5.5 Grams.
A 4 Pack is reduced to £12.50 when you use "DINGHYSHOW21".
www.sea-sure.co.uk/2520-stick-on-pad-i-4-pack-1312-p.asp
See our full range of products at www.sea-sure.co.uk
