FBW submit news (top)
Maritimo S55 - World Premiere
by Maritimo 12 Nov 2020 01:22 UTC
World Premiere of the new Maritimo S55 © Maritimo
Leading Australian luxury motor yacht manufacturer Maritimo is this week set to unveil an exciting addition to its internationally acclaimed S-Series sedan motor yacht range, with the announcement of the stunning new S55 sedan motor yacht at the Sanctuary Cove Boating Festival tomorrow.
The world premiere of the S55 will be in May 2021.
The new S55 is the latest addition to the esteemed sedan motor yacht series, a series renowned for long range adventuring, offshore cruising, build integrity' ocean tested stability and performance - features which form the foundation of Maritimo’s motor yacht building ethos.
“The new S55 offshore adventuring sedan motor yacht marks the first of an evolutionary design shift to the exterior form and styling within the S-Series sedan motor yacht range," said Maritimo's Director of Design Tom Barry-Cotter.
"The key practical design features of S-Series models past remain, with an array of exterior form advancements and additional features included.
Below The Surface
The new S55 hull is an advanced evolution of Maritimo’s longstanding experience in long range cruising design. The variable deadrise hull with deep keel, sharp bow entry and flattened progression aft has been focused on offshore cruising performance, comfort and stability. The foundations of the new S55’s hull design and engineering are centered on direct shaft drive technology. Maritimo has continually developed hull and engineering design specifically for shaft technology.
This focus and dedication to the development of shaft driven technology has positioned Maritimo as world leaders in shaft driven performance and long range cruising design. The direct shaft drives will be powered by standard twin Volvo Penta D11-670MHP power units with an option of Volvo Penta, Scania or CAT Power units up to 1000MHP. “Cruising efficiency and ocean proven dependability, are key to the concept of any long range motor yacht, and the S55 new generation hull design is set to be revolutionary in these categories,
The neutrally balanced wide beam hull and deep keel combined with low the centre of gravity will also give the S55 rock-like stability, creating the ultimate platform for adventuring, fishing and cruising” said Barry-Cotter. The hull design and engineering are based around an ultra-shallow angle straight shaft drive system which maximises efficiency, and focuses heavily on reduced draft to enhance versatility and create more cruising and destination options for owners.
A neutrally balanced weight distribution within the hull creates a well trimmed cruising experience that is capable of planning efficiently at all speeds, and aids visual sightlines from the helm position.
The advancements in cruising efficiency are multiplied further when combined with the S55’s 4550L (1200 US GAL) fuel capacity, meaning the new sedan motor yacht will be capable of adventuring further than ever before. The fuel system is comprised of three tanks that are designed to further lower the vessel’s centre of gravity and further increase stability. Wing tanks flanking each hull side gravity feed a 2300L (607 US GAL) main tank located along the S55’s keel line, keeping the main mass of fuel as low as possible in the hull, creating greater stability.
Above The Surface
The Maritimo S-Series sedan motor yacht has long been renowned for catering to a practical single level boating lifestyle. Socializing and entertaining flow seamlessly inside and outside from the upper cockpit to saloon on a singular level. The S55 has encompassed the successful idea of a practical deck space with its new adventure deck lower cockpit design. The adventure deck creates an incredible watersports or adventure haven with practical proximity to the water.
It incorporates the option to be opened with electric actuators to unveil a fully lined 2.8m (9’2”) tender garage with 250kg davit for owners looking to conceal tenders away from the rear platform. The adventure deck lower cockpit can also be integrated with an optional 1.4m (4’6”) extended platform to create a mammoth deck space with endless practical applications.
One step up from the lower cockpit, is the upper cockpit alfresco deck space, with easy access to deep walkthrough side decks. The upper cockpit is fully sheltered by the extended hardtop headliner, providing complete cover for the alfresco area. Adding further cover is the option for roll down breezeway or clears which provide complete 360 degree protection for the deck space. The design also conveniently conceals the clears with molded headliner recesses when stored.
The amount of floor space offered in the upper cockpit alfresco deck leads the market in the mid 50 foot category, with standard rear U-shape lounging and dining table and further option of opposing lounging flanking each side of the area. Maritimo is renowned for breaking the status quo, and the S55 is no exception. The expanded cockpit hardtop coverage has amplified the amount of area above, on the often-inaccessible sedan hardtop.
“Maritimo’s design division has maximised the practical deck spaces onboard the S55 by enabling the often un-used sedan hardtop to be accessed from the upper cockpit deck via overhead hatch and ladder, in order for the hardtop to be utilised as a utility deck space,”said Barry-Cotter. "The hardtop has been designed and engineered to be capable of carrying the weight of 350kg davit and tender freeing up the adventure deck and aft garage spaces for more entertaining or storage capability.
“The hardtop utility deck is also capable of storing large items such as kayaks, paddle boards or life rafts, for adventuring enthusiasts."
Maritimo’s iconic aft galley seamlessly connects the upper cockpit deck and the enormous saloon lounging area injecting light and air to the saloon and helm is the option of Maritimo’s unique two stage vista sliding windows which transform the areas into an indoor/outdoor escape. The saloon lounging area graciously integrates comfort, relaxation and the social hub of the vessel with the helm position.
Below deck the S55 offers three spacious staterooms and two ensuites, with full beam king master stateroom, offset queen forward stateroom and twin single starboard guest stateroom. The lower companionway allocates space for either combination or separate washer and dryer options.
“The new S55 brings together the combined skills and expertise of world class Maritimo craftsmen and epitomises our corporate culture and unyielding commitment to reaching motor yacht perfection,” said Barry-Cotter.
Much to be excited about for Maritimo in 2021
Luxury motor yacht manufacturer finished 2020 on a very successful note This year is set to be a very exciting and successful one for the award-winning Australian luxury motor yacht manufacturer, Maritimo. Posted on 31 Jan
Maritimo to take on world's best in Maritimo 11
Sleek 54 footer set to compete in the 2020 Sydney Hobart Yacht Race When the 116 year old ketch, Katwinchar, crossed the finish line in the 2019 Rolex Sydney Hobart Race after a grueling four days and six hours at sea a fire was ignited in the heart Australian boating industry legend and ketch owner, Bill Barry-Cotter. Posted on 18 Dec 2020
An unprecedented year for Maritimo in 2020
Maritimo closes 2020 with its one of its strongest ever forward order books and heightened interest Australia's leading luxury motor yacht manufacturer, Maritimo, closes 2020 with its one of its strongest ever forward order books and heightened interest in its range internationally. Posted on 10 Dec 2020
Maritimo ships $15m of new boats
A single shipment loaded with six luxury motor yachts all headed to their overseas owners Maritimo has ended the year on a strong note, with a single shipment loaded with six luxury motor yachts, headed to their overseas owners who are eagerly awaiting their early new year arrival. Posted on 8 Dec 2020
Successful Sanctuary Cove Boating Festival
Multiple orders secured for Maritimo The inaugural Sanctuary Cove Boating Festival last weekend, held in lieu of the 31st annual Sanctuary Cove International Boat Show this year, has been a major success for leading luxury motor yacht manufacturer Maritimo. Posted on 18 Nov 2020
Maritimo Sanctuary Cove Boating Festival Showcase
Sanctuary Cove Boating Festival starts tomorrow Four popular models from leading luxury motor yacht manufacturer Maritimo at its on water brand display are set to create a wave of interest at the Sanctuary Cove Boating Festival which starts tomorrow. Posted on 9 Nov 2020
Maritimo Racing - Staying prepared
Busily preparing for their UIM XCAT World Championship and Australian Superboat title defence Nearly one year has passed since Maritimo Racing has crossed the finish line of a Powerboat Grand Prix. The year 2020, and the Covid-19 pandemic, has seen almost all classes of international powerboat racing put on hold until further notice. Posted on 21 Oct 2020
Maritimo M70 Flybridge Motor Yacht
Virtual tour trailer shows you round the leader of the fleet Watch the brand new M70 trailer and discover a luxury motor yacht that is truly crafted to escape and explore. Posted on 13 Oct 2020
Maritimo's mighty flagships' success continues
The milestone was reached this month with a wave of recent deliveries Leading Australian luxury motor yacht manufacturer Maritimo's mighty flagship flybridge motoryacht models the M64 and M70 have surpassed an impressive milestone with over $100 million dollars of sales recorded since the world premiere. Posted on 3 Sep 2020
