Cummins at the Genoa International Boat Show: Light on board!
by Diesel International 4 Nov 2020 10:38 UTC
Cummins QSK50 © Diesel International
Cummins at Genoa Boat Show, with some interesting 'items' under the spotlights... Cummins Marine believed in Genoa Boat Show and the benefits were mutual (speaking of benefits, do you know Guidanz, the Cummins App?).
Cummins duly took advantage of the only limelight available to the marine audience, the Power Village in Genoa had two presences: unusual, the first, a premiere, the other.
Cummins at Genoa Boat Show. Talking about PG on board
We are talking, in order of description, about the QSK50-DM1 and the Onan C-Power QSB7.
It is infrequent to see the display of the 16-cylinder V-cylinder, if only for logistical reasons (thought flies to the harbor area of Ancona, in Italy too, at the International Fishing Fair, where a pavilion was once monopolised by large engines for fishing boats). The American super-square engine (BxS 159 x 159 millimetres), uses high pressure electronic fuel pumps, that deliver up to 1600 bar injection pressure and eliminate mechanical linkage adjustments, modular Common Rail fuel System (MCRS), and a dual cooling system, and provides flexible installation of the turbo, either vertically or horizontally.
The QSK50-Dm1, at 1,800 rpm, is able to provide up to 1,628 kW. The fixed speed version, like the one for propulsion, also adopts pistons with nitride coated rings and hardened cylinder liner. The electronics are equipped with a control unit to monitor the operating parameters, while providing complete engine diagnostics and protection. A single electrical interface for all boat connections reduces the complexity of the installation.
