Finally, a Bow Light that's comfortable to sit on
by John Czipri 3 Nov 2020 15:29 UTC
Accon Marine's 210-M LED Bowlight model (top) and 211-M model © Martin Flory Group
Protruding hardware on a boat can detract from its sleek foredeck, and is uncomfortable to sit or step on. The 210 Pop-Up® LED Bow Light from Accon Marine folds down flush into its base during the day and flips up with the touch of a button when night falls.
The Accon 210 Pop-Up LED Bow Light is US Coast Guard-approved for two nautical miles. It's built of polished marine-grade stainless steel for corrosion resistance and a contemporary appearance. The high-performance LEDs don't need to be replaced like incandescent bulbs, making it virtually maintenance-free. The lamp measures 112mm L x 102mm W and draws only 115mA.
Simple to install, the Accon Pop-Up LED Bow Light is available in through-bolt or stud-mount models. An included installation template notes the main 89mm and three fastener holes. It requires 68mm clearance. Both versions accept the optional plastic waterproofing cup to prevent runoff below deck. Accon's 211 Pop-Up LED Bow Light enables easy upgrades from its incandescent version, with a same-size cutout for drop-in replacement.
Snagged lines/falls avoided with Pop-Up Cleats
202 Series Pop-Up Cleat is available for virtually any size boat Snagging a line on a cleat while docking could have serious consequences, as can stubbing a toe and falling overboard. Both are easily avoided with Accon Marine's 202 Series of innovative Flush Mounted Pop-Up® Cleats. Posted on 19 Sep 2020
Pull-up Cleats enhance appearance of larger boats
Providing a cleaner overall appearance while eliminating a potential trip hazard Pull-up cleats add value to any boat by retracting flush into the deck when not required, providing a cleaner overall appearance while eliminating a potential trip hazard. Posted on 14 Aug 2020
Upgrading to quality Folding Cleats is simple
Retractable cleats enhance the safety and appearance of any boat Retractable cleats enhance the safety and appearance of any boat, but their required deck cut-outs may not be possible if there are bulkheads, electrical runs or other elements beneath. Posted on 25 Jul 2020
With an Accon Bimini Hinge, shade is seconds away
The 401 Quick Release Bimini Hinge is crafted from 316 stainless steel On a hot, sunny day, a bimini top offers cooling shade and protection from harmful UV rays. But one lost screw or pin can mean the entire assembly stays in storage. Posted on 10 Jun 2020
Pull-up line chocks enhance appearance, add safety
Accon Marine 500 Series retract flush into the deck when not in use Bow and stern chocks keep mooring lines from rubbing on the boat. But like any other protruding hardware, they're also trip and snag hazards. Pull-Up Line Chocks from Accon Marine solve this problem by retracting flush into the deck when not in use. Posted on 6 May 2020
LED Pop-Up Bow Lights set new standards
Unique retractable design helps protect the fixture from damage Traditional incandescent navigation lights with their fragile wire filaments are a pain to continually replace. They can also compromise occupant safety should they fail while under way. Posted on 13 Apr 2020
Quick Release Hanger make fender deployment a snap
Low-profile base and removable companion hinge ring that mounts permanently to the fender line Putting out fenders as a boat returns to the dock is always a bit of a chore, particularly for novices who may be uncomfortable tying knots or may lack experience gauging the correct height for placement. Posted on 26 Mar 2020
Update any boat with elegant Pull-Up Cleats
These cleats add class to any vessel in just minutes By retracting flush into the deck when not required, pull-up cleats enhance a boat's appearance and safety. A fully self-contained design makes installing 460 Series Pull-Up Cleats from Accon Marine an easy DIY project. Posted on 11 Feb 2020
Flush Mount Pole Holders clean up any skiff
Accon Marine's 708 Flush Mount Pole Holder comes in both ring-style and clip-style models Push poles have always presented challenges to anglers in skiffs. While the tool is effective for maneuvering in shallow water, the upright prongs used to stow it in transit often get in the way when fishing and can be easily damaged. Posted on 21 Jan 2020
Accon Marine Tie Downs provide ideal anchor points
They're ideal for use on poling or swim platforms Cast stainless steel Accon Marine Tie Downs provide ideal anchor points for holding fenders or equipment in place while blending discreetly into the deck. Posted on 3 Dec 2019
38 South - Marlin 695 Series 2 - FOOTERMarina Exchange FOOTER 1Sea Sure 2020 - SHOCK-WBV - FOOTER
