With Scrubbis, say goodbye to Speed-Robbing Hull Critters
by Martin Flory Group 24 Mar 15:04 UTC
A shag carpet of algae on the hull is bad enough, but barnacles, mussels, worms and other aquatic organisms rob a boat of its speed potential and are tough to remove. Unless the owner uses the Scrubbis Groovy attachment with the Davis Scrubbis™ Underwater Hull Cleaning Kit from Davis Instruments.
From the dock, deck or dinghy, it's easy to eradicate these tough, pernicious bottom-growing critters to achieve a clean, slick hull that's 30% faster and delivers as much as a 20% fuel savings.
The Scrubbis system is a 1.1-3.2m telescoping handle with a buoyant foam head and curved attachment to clean deep underneath the hull. Ideal for light scum, the head can be reversed to reveal a stiff cleaning fin for a more aggressive scrubbing. The device is slid down against the side and 2kg of flotation brings it back up, removing debris as it does.
For dormant boats that have accumulated serious growth, Scrubbis Groovy will tackle the nastiest of aquatic freeloaders. Easily swapped with the foam head of the Underwater Hull Cleaning Kit, it has rigid fibers that scour away debris for deep cleaning results. While tough on organisms, it won't scratch gelcoat or unduly wear away bottom paint.
For more information contact Davis Instruments, Tel: +1-510-732-9229; Fax: +1-510-732-9188. Outside the US/Canada: Tel: +1-954-928-1245; Fax: +1-954-928-1644. Email: or visit www.brungerexport.com.
Quick Fist and Super Quick Fist from Davis
A hand for yourself, one for the ship, and Davis has the third Boats are notorious for accumulating stuff. Much of it gets stowed, but for those items that need to be accessible at a moment's notice, there's Quick Fist® and Super Quick Fist® from Davis Instruments. Posted on 30 Jan
No wind, no fuel, grab the boat hook
For signaling, bright orange Davis paddles command attention Few things are as frustrating to a boat owner as being becalmed or running out of fuel—or both. If a tow isn't available, paddling is the next-best solution. Posted on 21 Dec 2019
19 tools fit into one pocket
A Snap Tool Multi-Key from Davis Instruments Carrying around 19 different tools requires a lot of pockets. Or, if it's a Snap Tool Multi-Key from Davis Instruments, just one. Whether pleasure boating, sailboat racing or fishing Posted on 15 Oct 2019
A clean hull without scrubbing
Scrubbis is easy to use With the Davis Scrubbis™ Underwater Hull Cleaning Kit from Davis Instruments, it's easy to rid a boat of algae, grass, barnacles and worm casings without getting wet—or hiring someone to do it. Posted on 2 Oct 2019
Removeable Chafe Guards save lines, protect boats
The quick solution to protect braided and three-strand cordage in high-wear areas As wind, currents and wake action move a boat in its slip, dock lines are constantly rubbing against the pier and vessel and being abraded. Posted on 2 Aug 2019
Happy Troller delivers tantalizingly slow speeds
Using Happy Troller is easy Experienced anglers know the importance of matching trolling speed to the target species. For tantalizingly slow lure presentations, the solution has traditionally been to use a trolling or kicker motor—both expensive propositions Posted on 20 Jul 2019
Move small boats safely with wheel-a-weigh
As nimble as they are on the water, small boats are awkward to move over dry land As nimble as they are on the water, small boats are awkward to move over dry land. By oneself or on a windy day, attempting it can be outright dangerous. Posted on 29 Jun 2019
Keeping a hull clean is fast, easy and inexpensive
Davis Scrubbis is a buoyant 40cm wide foam-like cleaning head Fresh, brackish or saltwater, there's always something that finds the bottom of a hull an irresistible place to live. Even with bottom paint, growth will develop that's not only unsightly, but robs the boat of its speed and fuel economy. Posted on 18 May 2019
Fewer Apps than a cell phone, but far more useful
Snap Tool Multi-Key has four SAE and three metric hex wrenches Cell phones have their place onboard, but even with all their apps they can't compare with the Snap Tool Multi-Key from Davis Instruments. About the same size, it packs 19 of the most useful boat tools into a pocket-sized package Posted on 12 Apr 2019
North or south, dirty boats need Davis FSR
FSR™ from Davis Instruments is the fast and easy to clean As northern boat owners start taking off winter covers, their southern counterparts are deep into mid-season. Both are invariably faced with dingy, dirty fiberglass that's lost its luster. Posted on 8 Mar 2019
