Update any boat in minutes with elegant Pull-Up Cleats
by Martin Flory Group 11 Feb 01:25 UTC
460 Series Pull-Up Cleats © Martin Flory Group
By retracting flush into the deck when not required, pull-up cleats enhance a boat's appearance and safety. A fully self-contained design makes installing 460 Series Pull-Up Cleats from Accon Marine an easy DIY project. Whether updating an existing boat or outfitting a new one, these cleats add class to any vessel in just minutes.
Made from 316 marine-grade stainless steel, 460 Series Pull-Up cleats come in 114mm, 152mm, 203mm and 254mm sizes. The various models handle mooring lines from 13 to 25mm. All have a mounded base that allows splashes or rainwater to run off the unit without pooling. Convenient integrated tabs make it easy to pull the cleat up, and a smooth top makes comfortable work of pushing it down flush to the deck after use.
Installation requires only painter's tape and a drill with a 22mm (7/8") hole saw. Simply mask out the area with tape and use the supplied template to mark the holes. Drill two 22mm (7/8") holes, remove the tape, and fit the cleat in place, securing it from below with included washers and locking nuts. A thread lock product such as Loctite helps complete the job.
To maintain, wash the cleat with soap and water to remove grime and dry with a soft cloth. A light spray coating of oil on moving parts helps this hardware provide a long service life.
For more information contact Accon Marine, Tel: +1-727-572-9202; Fax: +1-727-572-7621or visit www.acconmarine.com.
Flush Mount Pole Holders clean up any skiff
Accon Marine's 708 Flush Mount Pole Holder comes in both ring-style and clip-style models Push poles have always presented challenges to anglers in skiffs. While the tool is effective for maneuvering in shallow water, the upright prongs used to stow it in transit often get in the way when fishing and can be easily damaged. Posted on 21 Jan
Accon Marine Tie Downs provide ideal anchor points
They're ideal for use on poling or swim platforms Cast stainless steel Accon Marine Tie Downs provide ideal anchor points for holding fenders or equipment in place while blending discreetly into the deck. Posted on 3 Dec 2019
Adjustable Drink Holder fends off spills
Constructed from corrosion-resistant 316 stainless steel With family and friends bringing all sorts of plastic bottles, soda cans, travel mugs and insulated cozies onboard, spills are inevitable when these different-sized drinks won't fit in standard cup holders. Posted on 16 Nov 2019
Cleat/Rod Holder eliminates cockpit clutter
Once installed, maintaining this versatile hardware is simple Rigging the cockpit of a modern fishing boat can lead to frustration as multiple pieces of equipment often need to be installed in close proximity. Accon Marine's 9814 Cleat/Rod Holder combines two critical components into a single unit. Posted on 24 Oct 2019
Pop-up LED Bow Lights update the look of any boat
One quick and easy way to replace an old, dated bow light One quick and easy way to update the look of a boat is to replace an old, dated bow light. When upgrading to a compact LED Pop-Up Bow Light from Accon Marine, owners get the added safety of retractable hardware. Posted on 28 Sep 2019
Adding pop-up cleat convenience onboard is easy
Accon Marine 202 Pop-Up® Cleats require only basic tools for mounting Many owners prefer the clean appearance and added safety of retractable boat cleats, yet may not realize just how easy an upgrade installation is. Accon Marine 202 Pop-Up® Cleats require only basic tools for mounting Posted on 9 Aug 2019
Slim-Line Cleats deliver unprecedented versatility
Accon Marine Slim-Line Cleats are offered in 114mm, 152mm, 203mm and 254mm sizes Contemporary boat designs favor sleek, flowing forms with an emphasis on clean contours. Slim-Line Cleats from Accon Marine work well within this theme and have a versatile, space-saving configuration that fits where other retractable cleats won't. Posted on 2 Jul 2019
Mooring Cleats double as lifting eyes
Accon Lifting Cleats are made from 316 stainless steel Boat decks often seem to bristle with hardware, spoiling the vessel's smooth lines and creating potential tripping hazards. Accon Marine 209 Series Lifting Cleats combine lifting eyes and mooring cleats into a single multipurpose, integrated component. Posted on 13 Jun 2019
Accon enables easy addition of drink holders
Single and double drink holders utilize a thin, quick-release base One problem with traditional drink holders, whether permanently or temporarily mounted, is their bulky design limits where they can be used. Innovative single and double drink holders from Accon Marine instead utilize a thin, quick-release base Posted on 22 May 2019
Folding Cleat installs in minutes
Retractable cleats preserve a boat's lines and improve safety Retractable cleats preserve a boat's lines and improve safety, but can't always be installed where needed due to the presence of structural elements under the deck. Posted on 4 Apr 2019
Nanni Diesel Australia 2020 - FOOTERRaymarine AUS Element HV FOOTERMarina Exchange FOOTER 1
