Schmitt & Ongaro Mini Horns small on size, big on tone
by Martin Flory Group 1 Feb 2020 17:07 UTC
(Clockwise from left) Mini Drop-In, Mini Hidden Compact and Mini Compact Twin © Martin Flory Group
Stainless Steel Mini Horns from Schmitt & Ongaro Marine are the perfect solution for small boats where space is at a premium. Ideal for refit and OEM, six 12V models are available that top or flush mount, or install unobtrusively out of the way.
While the US Coast Guard doesn't have a minimum decibel rating for sound-producing devices on vessels under 12m, Schmitt & Ongaro's Mini Horns conform to ABYC A-23 standards. They offer sufficient volume for signaling over distance and have a clear, pleasing tone. Recordings of the single and twin Mini Horns are available here.
Mini Compact Single Horns are available in a weather-resistant Standard version or All Stainless Steel. They're ideal for installing above or below dashes, consoles and other exposed components. Measuring only 7.5cm L x 8cm W x 4.5cm H, they produce 105db at 1m FF 410Hz +/20 and draw only 3 amps.
The Standard and All Stainless Mini Hidden Compact Single Horns are designed to be unseen, but provide the same weather-resistance that Schmitt & Ongaro horns are known for. They measure 7.5cm L x 8cm W x 4.5cm H. They draw 3A and produce 105db at 1m FF 410 Hz +/20.
Flush-mount Stainless Steel Mini Drop-In Single Horns are available in high or low pitch, or paired together for a distinctive tone. Each measures 7.5cm L x 8cm W x 9.5cm H with a 12.3cm L x 7.6cm W grille, and require a 10.1cm hole. Producing 106db at 1m FF 410Hz +/20, they draw 3A.
Schmitt & Ongaro Mini Horns are pre-wired for fast and simple installation. They come with a five-year anti-rust and corrosion warranty and one-year on the internal electric contacts.
For more information contact Schmitt & Ongaro Marine Products, Tel: +1-717-431-2316; Fax: +1-717-431-2319. Email: or visit www.schmittongaromarine.com.
New wiper blades shrug off extreme conditions
New Deluxe Stainless Steel Wiper Blades from Schmitt Marine provide the clear view Salt, grime and UV rays degrade regular marine windscreen wiper blades, making them prone to streaking and chattering. Posted on 29 Sep 2023
Carbon Fiber Wheel provides luxury look
The sleek, modern beauty of this 34.3cm steering wheel belies its rugged construction For all the hours dedicated sportfishermen spend at the helm, the savvy ones know how to do it in comfort and style. Posted on 25 Aug 2023
Helm components match sportfish yacht elegance
Yacht Steering Wheels are made from highly polished cast 316 stainless steel Large offshore sportfish boats are both highly functional and remarkably beautiful. Posted on 29 Jul 2023
Wiper components ensure smear-free visibility
Schmitt Marine offers two models of wiper motors Whether in coastal waters or on an ocean crossing, vessels are required to maintain a proper lookout. In rainy conditions, Heavy Duty Wipers and Arms from Schmitt Marine keep windshields clear and smear-free for maximum visibility. Posted on 13 May 2023
Durable Steering Wheel provides positive grip
Polyurethane Destroyer Wheel has five polished stainless steel spokes The Polyurethane Destroyer Wheel from Schmitt & Ongaro Marine features a durable covered rim that provides commercial mariners and recreational boaters the positive grip needed for optimal control when running in foul weather. Posted on 28 Jun 2022
Schmitt & Ongaro Marine PU50 steering wheel
New premium steering wheel delivers right-priced quality Schmitt & Ongaro Marine's new model PU50 steering wheel is a premium-quality addition to the helm of any runabout, pontoon, center console or watersport boat. Posted on 27 Jan 2022
Mini Schmitt & Ongaro Horns are mighty in volume
Standard and All Stainless Mini Compact Single Horns are ideal for a wide range of installations Extremely adaptable, Schmitt & Ongaro Mini Horns will fit in the tightest of spots and can be top- or flush-mounted, or hidden inside the boat. Posted on 26 Oct 2021
Schmitt & Ongaro Primus Wheel checks all the boxes
The first thing that typically catches the eye of a true boat lover is the helm The first thing that typically catches the eye of a true boat lover is the helm. And few things convey more about a vessel's quality and seaworthiness than its steering wheel. Posted on 3 Sep 2021
Luxury Marine Steering Wheel has appealing price
The 356mm Model 30 has a hand-feel suggesting a high-end automobile Few things on a boat exude luxury as much as its steering wheel. The 356mm Schmitt & Ongaro Marine Model 30 has a hand-feel suggesting a high-end automobile, but at a price that makes it the perfect complement to ski boats, runabouts, RIBs, pontoons Posted on 7 Aug 2021
Trumpet Horns produce volume while adding style
Deluxe All Stainless Steel Trumpet Horns are available in single and dual versions Whistles may satisfy regulatory requirements and function as sound-producing devices, but they pale in comparison to a true horn. Posted on 19 Jun 2021
