With Snap Tool Multi-Key, 19 tools fit into one pocket
by Martin Flory Group 15 Oct 2019 13:53 UTC
With Snap Tool Multi-Key, 19 tools fit into one pocket © Martin Flory Group
Carrying around 19 different tools requires a lot of pockets. Or, if it's a Snap Tool Multi-Key from Davis Instruments, just one. Whether pleasure boating, sailboat racing or fishing, it's the one palm-sized item that will always be ready to twist, cut, pry, snap and take care of any number of needed onboard jobs.
A veritable toolbox, the patented Snap Tool Multi-Key has three metric and four SAE hex wrenches, slotted and Phillips screwdrivers, a scraper and a recessed cutting blade. Three deck plate keys open any deck fill. A shackle tool unscrews even corroded pins. The button snapper, unsnapper and zipper pull are perfect for dirty and shrunken canvas. A convenient lanyard hole allows it to be worn around the neck. And once the boat is moored, a bottle opener helps end a perfect day.
The Snap Tool Multi-Key is 7cm wide by 11.4cm long—about the size of a playing card. It's stronger and thicker than all other deck plate keys, yet only weighs 80 grams. It's made from hardened 304 stainless steel for long-lived corrosion resistance.
For more information contact Davis Instruments, Tel: +1-510-732-9229; Fax: +1-510-732-9188. In Europe: Davis Marine Europe Tel: +31 (0)78 6194316; Fax: +31 (0)78 6192689. Email: , or visit www.davisinstruments.com.
