Delta "T" debuts new Axial Replacement Fans
by Martin Flory Group 1 Oct 2019 14:29 UTC
Euro Style Axial Replacement Fan © Martin Flory Group
Too often, international boatbuilders have to retrofit ventilation components. Not so with Delta "T" Systems' new Euro Style Axial Replacement Fan. Made in the USA, it delivers superior performance and build quality and is designed for vessels made outside North America, whether for new construction or refit.
The Euro Style Axial Replacement Fan is available in custom diameters from 315mm-800mm. Unlike common European steel models, its housing is welded marine-grade aluminum that's powder-coated for corrosion resistance and a high-end appearance. It matches original metric fan sizes and flange bolt patterns for easy installation.
Delta "T" Systems uses high-efficiency composite blades in the Euro Style Axial Replacement Fan. Powerful, quiet and replaceable, they deliver improved performance over original European fans in both airflow and power draw.
The Euro Style Axial Replacement Fan is available with single or three-phase motors, in 50 and 60 Hz and in a range of voltages, to fit any application for worldwide use. Balanced corrosion-resistant aluminum hubs attach directly to the shaft with multiple locking methods for safety, reliability and long-lived, vibration-free operation.
Installed on over 18,000 commercial, recreational and military vessels worldwide, Delta "T" Systems' products are known for their innovation and high quality. It engineers and manufactures complete marine machinery space ventilation systems for refit, custom build and OEM applications.
For more information contact Delta "T" Systems, Tel: +1-561-204-1500; Fax: +1-561-848-1611. Email: or visit www.deltatsystems.com.
