Adjustability of Schmitt & Ongaro Wipers sets them apart
by Martin Flory Group 28 Sep 2019 16:12 UTC
Schmitt & Ongaro Wipers © Martin Flory Group
Many boats have wipers that don't clean the entire windshield or simply stop mid-sweep when switched off. The Schmitt & Ongaro Marine Products Heavy Duty Waterproof Wiper Motor not only delivers long-term durability, but also provides the ability to easily set the arm(s) for sweep and direction, as well as a self-park function. Available in 12 or 24 volts, it's the perfect solution for OEMs and as an aftermarket replacement.
Unlike many wipers on the market, the Schmitt & Ongaro Heavy Duty Waterproof Wiper Motor adjusts for a 40 degrees-110 degrees sweep in 10 degrees increments left or right and will self-park. This provides the ability to dial-in the maximum windshield coverage of the blade.
Configuring the Heavy Duty Waterproof Wiper Motor is straightforward using common household tools. The internal angle plate is clearly labeled and detailed instructions are included.
IP66-rated, the Heavy Duty Waterproof Wiper Motor has a 316 stainless steel shaft with brass and nickel-plated shaft housing and an aluminum cover for heat dissipation and corrosion resistance. It is available in three shaft sizes, 38.1mm, 63.5mm and 88.9mm, and has two speeds, 35 and 55 sweeps per minute. With 11 ft-lb of torque, it'll drive up to 60.9cm arms with 60.9cm blades effortlessly. The device features insulated grounding for use on any hull material, and is EMC protected and CE approved. It comes with a limited three-year warranty. Schmitt & Ongaro wiper system components can be purchased separately, including a wiper control box, motor, switch and wiper arms and blades.
Schmitt & Ongaro Marine Products manufactures a wide range of innovative and superior quality marine steering wheels, horns, wiper systems, control arms and knobs, and accessories. The company offers some of the strongest product warranties in the industry and exceptional customer service.
For more information contact Schmitt & Ongaro Marine Products, Tel: +1-717-431-2316; Fax: +1-717-431-2319. Email: or visit www.schmittongaromarine.com.
Marine Steering Wheel provides right-priced luxury
The new Model 40 marine steering wheel is the perfect addition to runabouts The new Model 40 marine steering wheel from Schmitt & Ongaro Marine Products is the perfect addition to runabouts, ski and wake boats, pontoons and other small recreational vessels. Posted on 15 May
Mini horns small on size, big on tone
Stainless Steel Mini Horns from Schmitt & Ongaro Marine Stainless Steel Mini Horns from Schmitt & Ongaro Marine are the perfect solution for small boats where space is at a premium. Ideal for refit and OEM, six 12V models are available that top or flush mount, or install unobtrusively out of the way. Posted on 1 Feb
Schmitt & Ongaro wheel offers contemporary design
Ideal for ski and wake boats, runabouts, cuddy cruisers and pontoons Schmitt & Ongaro Marine Products' new 356mm Model 30 marine steering wheel is a striking, contemporary design by Stella. It's ideal for ski and wake boats, runabouts, cuddy cruisers and pontoons. Posted on 31 Dec 2019
22.8cm Grab Rail new range of install methods
Schmitt & Ongaro fitting can be wood or cap screw mounted Every boat has that one spot where a grab rail is needed, but was never added due to the complexity of the installation. Schmitt & Ongaro Marine's 22.8cm Top-Mounted Grab Rail can be wood or cap screw mounted Posted on 23 Aug 2019
New Primus Wheel evokes a range of moods
The new powder-coated Primus steering wheel from Schmitt & Ongaro Marine Depending on the boat it graces, the new powder-coated Primus steering wheel from Schmitt & Ongaro Marine Products can be tactical, race-inspired, sophisticated or rebellious. Posted on 31 Jan 2019
Nine sizes of Destroyer Wheel
Classic good looks and robust stainless steel construction Most marine steering wheels designs come and go, but one has withstood the test of time: the Schmitt & Ongaro Marine Destroyer Wheel. With classic good looks and robust stainless steel construction, it's available in seven sizes, from 279mm to 762mm. Posted on 7 Dec 2018
Schmitt & Ongaro makes replacing wipers easy
Long-lasting Standard Wiper Motor Kits Inoperable windshield wipers make it difficult to maintain a proper look-out when heavy rain and driving spray obstruct the view. Schmitt & Ongaro Marine Products offers a line of durable, long-lasting Standard Wiper Motor Kits Posted on 31 May 2018
Trumpet horns 100% waterproof
Schmitt and Ongaro Marine Deluxe all stainless steel single and dual trumpet horns Almost every country requires a sound signal appliance for vessels up to 11.9m. They don't comment, however, on how long the device should last or the quality of its sound. Posted on 12 Apr 2018
New stainless Primus wheel is ergonomic & durable
Maximum ergonomic all-day comfort from Schmitt & Ongaro Marine Few components on a boat are touched as frequently as its steering wheel. That's why Schmitt & Ongaro Marine designed Primus, its new cast stainless steel steering wheel, to deliver maximum ergonomic all-day comfort. Posted on 23 Mar 2018
Hub Extension adds 38MM to Schmitt & Ongaro Wheels
Schmitt & Ongaro Marine's Aluminum Hub Extension is the solution OEMs Whether to increase leg room, optimize a standing position or provide added clearance for improved dash access and visibility, Schmitt & Ongaro Marine's Aluminum Hub Extension is the solution OEMs and boat owners need. Posted on 12 Dec 2017
