Marine Elegance Toilet provides wide selection of options
by Martin Flory Group 28 Sep 2019 14:04 UTC
Marine Elegance Toilet © Martin Flory Group
The Marine Elegance™ from Raritan Engineering is the ultimate electric marine toilet. It's also one of the most adaptable and easily installed marine toilets on the market today. It provides the option to flush with onboard fresh or outside raw water and features hidden hardware for a clean, custom appearance.
Offering the luxury of a full-size residential seat, the sleek Marine Elegance is available in four variations—two heights and a straight or angled back—and two colors, white or almond. Its slow-close seat has stops to help prevent shifting when using while under way. Combined with a unique mounting system and small base, it will fit into almost any head compartment.
The Marine Elegance uses Vortex-Vac™ technology that creates a vacuum in the bowl, thereby eliminating the need for extra suction generation equipment. With unmatched rinsing capability, the efficient action of the pump quickly and quietly pulls the waste from the toilet and has the power to move it an impressive 3m vertically and 30m horizontally. Performing at a noise level less than 63 decibels, it won't alert everyone in the boat or on the dock that nature called. A built-in shredder with stainless steel blades transforms waste into small particles that virtually eliminates clogs.
The Marine Elegance is available with SeaFresh. This innovative option allows the toilet to operate using onboard fresh or external water with the flip of a switch. This is especially helpful to reduce odors associated with raw seawater when leaving the boat for extended periods.
Raritan's fully-programmable Smart Flush Control provides users complete control for optimal flushing. An environmentally-friendly low water option helps conserve precious onboard water and extends the useful capacity of most holding tanks. With the available Bluetooth Flush Control, not only can the sanitation device be optimized remotely, but diagnostic data is stored for troubleshooting.
The Marine Elegance toilet measures 467mm L x 355mm W. The Standard model is 305mm H, while the Tall is 432mm H. It's available in 12V or 24V, and draws 30 or 20 amps, respectively.
For more information contact Raritan, Tel: +1-856-825-4900; Fax: +1-856-825-4409.Email: or visit www.raritaneng.com.
Protecting a macerator pump is simple with Raritan
The Smart Macerator Control provides comprehensive protection Raritan Engineering's Smart Macerator Control monitors and maintains pump motors to prevent damage. It provides owners with peace of mind that a vital component will remain operational. Posted on 16 Jan 2019
Servicing a Macerator Impeller is fast and easy
Raritan's Macerator Pump has few rivals The realization that a macerator pump needs servicing leaves many boat owners sighing with despair. It's a seriously nasty job. Even if a technician does the dirty work, it'll take days to get rid of the odor. Posted on 24 Nov 2018
Raritan offers longest-lived water heaters
Boats never seem to have enough hot water to satisfy demand Whether for cooking or bathing, boats never seem to have enough hot water to satisfy demand. It's a different story when a 1700 Series Water Heater from Raritan Engineering is on board. Posted on 25 Sep 2018
Raritan Toilet eliminates cross-contamination
Keeping fresh and waste water separate is essential on a boat Keeping fresh and waste water separate is of the utmost importance on a boat. With Raritan's SeaEra Electric Macerating Toilet, there is never the possibility of waste water contaminating the contents of the bowl Posted on 26 Jul 2018
Raritan makes DIY Toilet Repairs Easy
Raritan offers everything from a simple O-ring to complete pump assemblies Many boat owners prefer to maintain and repair onboard systems themselves to save time and money. Raritan Engineering supports these DIYers. All its easy-to-install manual and electric toilets have only a handful of wearable parts—all Posted on 26 May 2018
Raritan Toilet flushes with fresh or sea water
Four different controls are offered for the Marine Elegance The days of using limited on board potable water supplies to flush a toilet are at an end with Raritan Engineering's line of eight Marine Elegance™ electric toilets with the SeaFresh option. Posted on 30 Mar 2018
Raritan Icerette overcomes environmental extremes
Ice makers face environmental extremes that make consistent performance a challenge On board ice makers face environmental extremes that make consistent performance a challenge. Raritan Engineering's Icerette Model 87 overcomes heat, high humidity, full sun and salt spray, making 21 lbs. of ice a day, with a sleek, modern style Posted on 13 Feb 2018
