Nanni Diesel 2019 Leaderboard
USB Receptacles directly charge latest electronics
by Martin Flory Group 14 Aug 11:36 UTC
Keeping the myriad portable electronic devices charged while on a boat used to require sacrificing electrical outlets to plug-in adapters. Hubbell Marine USB receptacles have room for both electronics and two- or three-pronged connections in a stylish design that's still a standard size.
Hubbell Marine USB Charger Receptacles are available in configurations of two standard inlets plus two Type-C ports, two legacy Type-A or a combination of one of each. The 5 amp, 5V DC USB output is powerful enough to charge two tablets simultaneously. It also effortlessly handles cell phones, handheld games, wireless headphones and other devices.
For additional durability, Hubbell offers a weather-resistant version of the combination Type-A and -C model that, with a cover, meets Section 406.9 of the National Electrical Code. It features an LED light to indicate power is on.
Hubbell Marine USB Charger Receptacles are available in popular ivory, light almond and white, as well as black, brown and gray. All are rated tamper-resistant.
For more information contact Hubbell Marine Electrical Products, Tel: +1-475-882-4838 or visit www.hubbell-marine.com.
Hubbell brings DC Power to Electric Reel Systems
Hubbell Marine electric reel system are a 30 amp locking receptacle Large electric fishing reels typically use DC power, yet finding suitable marine-grade outlets and plugs for electrical connections can be challenging. Rather than attach clamps to a battery, or risk dangerous accidental use of an AC outlet Posted on 27 Jun
GFCI Receptacle protects against shock
An electrical outlet capable of monitoring and shutting itself off Having an electrical outlet capable of monitoring and shutting itself off makes for one less thing to worry about while on the water. Areas such as the galley or head can be made much safer by utilizing ground fault circuit interrupter receptacles. Posted on 23 May
Stainless Flip Covers add elegant touch of bling
Hubbell Marine Stainless Steel Flip Cover features an elastomer base gasket While electrical receptacles mounted in exposed areas need to be protected with covers, traditional plastic caps don't always suit the contemporary styling of modern yachts and marinas. Posted on 20 Apr
Pop-up Countertop Receptacles are UL-Listed
Hubbell Marine's new Countertop Receptacles install discretely in the countertop Electrical outlets in a galley or head are typically located on a wall or the side of cabinetry, and often too far away from where they're needed. Hubbell Marine's new Countertop Receptacles install discretely in the countertop for maximum convenience. Posted on 1 Feb
Hubbell Marine improves its 100A line
Now UL witnessed IP69k rated for water and dust ingress protection and UL Type 4X and 12 approved Hubbell Marine's 100A ship-to-shore pin and sleeve cable sets, connectors and inlets have a well-deserved reputation for maximum electrical transfer and unequaled toughness. Posted on 26 Dec 2018
Twist-Lock Circuit Tester quickly diagnoses issues
Hubbell Circuit Tester is compact and durable For boat owners using shore power, knowing if electrical systems are safe and functional is crucial. The 30A/125V Hubbell Twist-Lock® Circuit Tester can quickly diagnose if power is present and if equipment is wired correctly. Posted on 2 Nov 2018
New Ground Fault Receptacle is corrosion resistant
Electrical receptacles on a boat or at a boatyard/marina can easily be compromised The electrical receptacles on a boat or at a boatyard/marina can easily be compromised due to corrosion or the rugged conditions that often exist in today's marine environment. Posted on 4 Oct 2018
Isolation Transformers compensate for low voltage
Hubbell Marine offers 15 and 25 kVA Isolation Transformers with an optional 12.5% Auto-Boost. During start-up, Hubbell Auto-Boost immediately assesses the electrical system and can automatically boost the output by 12.5% to compensate for low voltage. Posted on 18 Sep 2018
Shore Power Cable Set is safe and watertight
Water and electricity do not mix Water and electricity do not mix. Having a waterproof shore power cable set is of vital importance to the safety of boaters and their watercraft. Hubbell Marine 30A models incorporate a molded design, completely encased in solid PVC material Posted on 29 Jul 2018
Ship-to-shore cable sets
Experienced boaters may carry multiple shore power cables onboard Experienced boaters may carry multiple shore power cables onboard, particularly when cruising to new ports where longer or shorter lengths may be preferred. Posted on 31 May 2018
Raymarine AUS Element HV FOOTERMarina Exchange FOOTER 1Nanni Diesel 2019 Footer
