With boat theft on the rise, now's the time for CamBoat
by Martin Flory Group 16 Jul 2019 13:54 UTC
CamBoat™ from Glomex © Martin Flory Group
Every day, boat owners become victims of theft—either valuable electronics and engines or the entire vessel. With CamBoat™ from Glomex, adding a high-definition security camera is a cost-effective measure to help prevent break-ins and provide valuable information to recover stolen property should the worst happen. Requiring only Wi-Fi access, it has no monthly fees, cloud services or subscriptions.
CamBoat is simple to install and use. Owners can view the live video and audio feed at any time using the Glomex app. Because it's completely private with one-to-one encryption, they're the only ones who will see and hear the device. It has an 80 degrees field of view and night vision capability. An integrated motion sensor records onto its built-in SD card for 24/7 surveillance.
Engineered specifically for marine applications, CamBoat is IP65-rated for use above or below deck. It works in a wide range of conditions, from 10 degrees-50 degrees C. Because of its compact size—89mm in diameter x 84mm high—it'll fit anyplace its 12V DC power supply will reach. It has a maximum amperage draw of 230mA. CamBoat may be used by itself, but it's also a component of Glomex's award-winning ZigBoat™ monitoring system, an innovative network of sensors that notify if critical vessel events occur.
For more information contact Glomex s.r.l., Tel: +39 0544500377. Email: ; or visit www.glomex.it.
