Hubbell brings safe DC Power to Electric Reel Systems
by Martin Flory Group 27 Jun 2019 00:58 UTC
Hubbell DC Power to Electric Reel Systems © Martin Flory Group
Large electric fishing reels typically use DC power, yet finding suitable marine-grade outlets and plugs for electrical connections can be challenging. Rather than attach clamps to a battery, or risk dangerous accidental use of an AC outlet, owners can install a complete Hubbell Marine DC-rated solution for powering their rigs.
Standard components of the Hubbell Marine electric reel system are a 30 amp locking receptacle, plug and connector. Each is rated at 28V DC for use with all 12V, 24V and 32V fishing reels. Their unique configuration ensures they can't accidentally be plugged into an AC-rated power supply. All pieces are UL listed and CSA certified.
These Hubbell Marine electrical products use nickel-plated contacts for extreme corrosion resistance. Integral rear seals on plugs and connectors protect internal components from dust and foreign matter. High-visibility yellow nylon casings are impact resistant and UV stabilized to assure years of reliable performance. Adding a Hubbell outlet box and weatherproof spring-loaded lift cover—both available in yellow, white or gray—completes the marine-grade package.
For more information contact Hubbell Marine Electrical Products, Tel: +1-475-882-4838 or visit www.hubbell-marine.com.
Hubbell Cable Sets deliver safety features
Twist-Lock 50A Cable play an important role in enhancing dockside safety for boat owners Despite a marina owner's best efforts, electrical problems at the pedestal may not be immediately diagnosed. Posted on 4 Aug 2023
Hubbell Marine offers a full line of components designed expressly for DC-powered reels Electric reels are popular with offshore fishermen in spite of sometimes being awkward to connect to a power supply. Posted on 16 Feb 2023
Durable 316 stainless steel construction delivers a long service life Seasoned mariners know that watertight integrity is critical for reliable shore power connections. Stainless steel 30A and 50A inlets from Hubbell Marine assure dependable performance in a timeless design that now benefits from recent technical updates. Posted on 6 Apr 2022
USB Receptacles keep phones and tablets charged
Now including USB Type A or Type C ports With both boats and boaters having become more connected than ever, there's never been greater need to keep portable devices fully charged while under way. Posted on 17 Mar 2022
Circuit Tester simple to use
LEDs on Hubbell Marine HBLT26CM11 Twist-Lock Circuit Tester glow bright enough to be seen in sun Multimeters are ideal for testing electric wiring, but their use requires specialized knowledge. Not so with the HBLT26CM11 Twist-Lock® Circuit Tester from Hubbell Marine. Posted on 5 Feb 2022
