Construction updates: Blue View Bayliss 78'
by Bayliss Boatworks 5 Jun 2019 10:01 UTC
Blue View Bayliss 78' © Bayliss Boatworks
The month of May brought several new teak additions to Blue View (Bayliss 78'). The most noteworthy of which was the installation of her raised teak flybridge deck. Work is now under way on her teak transom. Later this month, the crew will begin on her teak coverboards.
On the flybridge, her console is now in final primer. The cabin, bridge, and hull are in the process of being sanded and will soon match the console in final primer.
Stepping into the interior of Blue View, things are beginning to take shape. The interior carpentry crew has completed the build out of the galley, dinette, and day head. They are now turning their attention to tackle room build out. Fabrication of everything from the VIP bunks to galley cabinetry is well under way inside the cabinetry shop.
Our electrical crew is currently completing the main wire runs for all lighting and equipment. Our mechanical crew just installed her struts, and over the course of the next month, they will build generator exhaust piping, install chiller lines, and plumb the machine tunnel bilges and sumps.
Soon, she will receive her teak helm pod and half round, inching her exterior appearance one step closer to finalization.
Read more at baylissboatworks.com/boats/b24
Bayliss 75' construction update
The cabin has been coated in adtech and sanded down for fairing At the end of May, the hull jig was constructed. Our hull carpentry crew will now begin shaping the bow stem, closely followed by in the installation of the chine, sheer, and stringers. Posted on 10 Jun
Old Reliable - Bayliss 72' construction update
With walls in place, we see a first glimpse of the lower-level layout The forward area has taken shape- interior walls are up! With walls in place, we are seeing our first live glimpse of the lower-level layout, which will be comprised of four staterooms and three heads. Posted on 8 Jun
Bayliss 62' construction update
'Seven's bow deck, cabin and flybridge transition from fairing to final primer The exterior carpentry crew continues to develop the mezzanine and engine room companionway. Mezzanine stainless refrigerator/freezer liners are nearly ready for installation in the mezzanine and have already been installed on the flybridge. Posted on 6 Jun
Salty Tiger is approaching her delivery date Salty Tiger is approaching her delivery date as we move into June. In mid-May, after her first sea trial, she revealed her top speed to be over 47-knots, yielding a 41-knot cruise at 2150; the same as her sister ship, Tarheel (Bayliss 62'). Posted on 4 Jun
Blue View - Bayliss 78' construction update
A product of over 71,000 man hours and nearly 30 months of labor Blue View is powered with MTU M96L 16V engines, each with 2,600 horsepower. Her top speed was registered at over 44 knots at completion. This top end speed translates to a 37.5-knot cruise at 2150. Posted on 2 Jun
The console transitioned from jig, to core-cell, to glass, and is currently in ad tech Cabin glassing on Bayliss 75' was completed in mid-April, after which our crew turned their attention to fabricating the flybridge and console. Posted on 7 May
Salty Tiger - Bayliss 62' construction update
Cabinetry installations have quickly progressed In early April, Salty Tiger's transom artwork was encased in layer upon layer of clear coat. On the interior, cabinetry installations have quickly progressed. Posted on 6 May
The engine room transitioned from adtech to fairing Old Reliable's engine room and pump room underwent quite the transformation over the month of April. The engine room transitioned from adtech to fairing, and after several rounds of sanding, finally primer. Posted on 5 May
Seven - Bayliss 62' construction update
Both the toe rail and cockpit deck were installed on Seven! In April, both the toe rail and cockpit deck were installed on Seven! Throughout the latter half of the month, the toe rail underwent glassing, fairing and adtech. Posted on 4 May
Inching closer to her delivery later this month Our crews have been hitting big milestones on Blue View! We are seeing finalizations daily as we inch closer to her delivery later this month. Posted on 3 May
