Larson Electronics releases 18W LED Boat Light Bar, 1,400 lumens, 10-30V DC, IP67 waterproof rated
by Rob Bresnahan 16 Feb 2019 22:28 UTC
Larson Electronics 18W LED Boat Light Bar © Larson Electronics
Larson Electronics, a Texas-based company with over 40 years of experience spearheading the industrial lighting sector, announced the release of an 18-watt LED boat light bar for use on a variety of boat types. This compact light produces 1,400 lumens with a color temperature of 6000K. This unit offers a 30,000-hour lifespan with a low amp draw and 10V to 30V compatibility.
The RE-BL-LED-FM-IL.18 LED boat light bar features six high output 3-watt LEDs each producing 233 lumens set in rows and paired with high purity optics. This fixture produces a wide 60° flood beam that shines 40 feet long and 60 feet wide. This light bar produces bright light while drawing 18 watts at 1.4 amps from a 12V electrical system. The LED lights are IP67 waterproof rated up to three meters and sealed to resist dust and dirt and made to withstand harsh, wet environments.
Larson Electronics' boat light bar can withstand rapid temperature changes of -40°C to 85°C and features housing made of extruded diecast aluminum with unbreakable polycarbonate lenses. This fixture can be mounted flush with four thru holes in the faceplate or mounted with the stainless-steel trunnion U bracket. This unit is suitable for use in high humidity, extreme cold, and rough saltwater conditions.
