Protecting a macerator pump is simple with Raritan
by Martin Flory Group 16 Jan 2019 05:48 UTC
Raritan Engineering's Smart Macerator Control © Raritan
Macerator pumps, hidden from view, aren't thought of too oftenuntil they stop working. Then, it becomes a messy, dirty job to repair or replace.
Raritan Engineering's Smart Macerator Control monitors and maintains pump motors to prevent damage. It provides owners with peace of mind that a vital component will remain operational.
The Smart Macerator Control provides comprehensive protection. If the macerator pump doesn't prime in seven seconds or runs dry for five, it automatically shuts it down. Additionally, it continually monitors amperage; if there's more than a 20A draw, it turns it off.
The Smart Macerator Control is ideal for vessels that are left unused for lengths of time. If power is left on, the control jogs the macerator pump a few milliseconds every seven days to prevent impeller binding.
If the Smart Macerator Control does shut down a pump due to a priming issue or running dry, an LED light flashes at the main switch. If an amperage overload is detected, it remains illuminated. Resetting the control is as simple as turning the switch off and on.
At 158mm x 38mm, the Smart Macerator Control easily fits into tight, protected spaces. It works with Raritan 53100 and 53101 Macerator Pumps.
Contact Raritan, 530 Orange St., Millville, NJ 08332 USA. +1-856-825-4900; Fax: +1-856-825-4409. ; raritaneng.com.
Marine Elegance Toilet provides wide options
One of the most adaptable and easily installed marine toilets on the market today The Marine Elegance™ from Raritan Engineering is the ultimate electric marine toilet. It's also one of the most adaptable and easily installed marine toilets on the market today. Posted on 28 Sep 2019
Servicing a Macerator Impeller is fast and easy
Raritan's Macerator Pump has few rivals The realization that a macerator pump needs servicing leaves many boat owners sighing with despair. It's a seriously nasty job. Even if a technician does the dirty work, it'll take days to get rid of the odor. Posted on 24 Nov 2018
Raritan offers longest-lived water heaters
Boats never seem to have enough hot water to satisfy demand Whether for cooking or bathing, boats never seem to have enough hot water to satisfy demand. It's a different story when a 1700 Series Water Heater from Raritan Engineering is on board. Posted on 25 Sep 2018
Raritan Toilet eliminates cross-contamination
Keeping fresh and waste water separate is essential on a boat Keeping fresh and waste water separate is of the utmost importance on a boat. With Raritan's SeaEra Electric Macerating Toilet, there is never the possibility of waste water contaminating the contents of the bowl Posted on 26 Jul 2018
Raritan makes DIY Toilet Repairs Easy
Raritan offers everything from a simple O-ring to complete pump assemblies Many boat owners prefer to maintain and repair onboard systems themselves to save time and money. Raritan Engineering supports these DIYers. All its easy-to-install manual and electric toilets have only a handful of wearable parts—all Posted on 26 May 2018
Raritan Toilet flushes with fresh or sea water
Four different controls are offered for the Marine Elegance The days of using limited on board potable water supplies to flush a toilet are at an end with Raritan Engineering's line of eight Marine Elegance™ electric toilets with the SeaFresh option. Posted on 30 Mar 2018
Raritan Icerette overcomes environmental extremes
Ice makers face environmental extremes that make consistent performance a challenge On board ice makers face environmental extremes that make consistent performance a challenge. Raritan Engineering's Icerette Model 87 overcomes heat, high humidity, full sun and salt spray, making 21 lbs. of ice a day, with a sleek, modern style Posted on 13 Feb 2018
Marina Exchange FOOTER 1Raymarine AUS Element HV FOOTERNanni Diesel Australia 2020 - FOOTER
