Pull-Up Cleats combine style and function
by Martin Flory Group 2 Oct 2018 03:33 UTC
Pull-Up Cleats combine style and function © Martin Flory Group
There is a fine line between the necessity for hardware durable and large enough for a yacht, and the desire to maintain its elegant flowing profile. Accon Marine's flush-mounted 30cm and 38cm Pull-Up Cleats walk that line perfectly. They are engineered for vessels over 12m with marine-grade 316 stainless steel and neatly stow inside their own base when not in use.
Despite their high level of convenience, cleats can be unsightly and get in the way when not in use. Not so with the flush-mounted 30cm and 38cm Pull-Up Cleats. When the user is ready to tie up, they simply pull the cleat above deck. In addition to its rugged, stainless steel construction, each cleat comes with a waterproofing cup. An included backing plate also serves as the cut-out template, making installation simple.
Accon's 30cm cleat measures 15cm deep, is 9cm at its widest point and can safely handle 6,350kg. The 38cm cleat safely holds 9,071kg and is the largest flush-mounted cleat available. It measures 13cm at its widest point and extends 18cm deep. The 38cm Pull-Up Cleat is available in through-bolted and stud mount versions. The 10cm stud mount lets the cleat attachment points stay concealed to preserve a yacht's elegant appearance.
