Ship-to-shore cable sets suit wide range of applications
by Martin Flory Group 31 May 2018 15:51 UTC
Ship-to-shore cable sets suit wide range of applications © Martin Flory Group
Experienced boaters may carry multiple shore power cables onboard, particularly when cruising to new ports where longer or shorter lengths may be preferred. Dependable marine-grade, 100 amp ship-to-shore cable sets from Hubbell Marine come in lengths of 15.2, 22.8, 30.4 and 30 meters to accommodate a wide range of port facilities.
Hubbell Marine offers 3, 4 and 5-wire 100 amp cable sets. Built to meet or exceed the highest quality standards, they use durable pin and sleeve connectors that are fully ABYC compliant and UL listed for maximum performance and durability. In fact, Hubbell developed the standard for 100 amp pin and sleeve devices with the National Electric Code and ABYC.
The high-visibility yellow STOW cable is the only UL-listed shore power cable truly rated for a full 100 amps, and at temperatures of up to 105 degrees C for reliable performance. Watertight and corrosion-resistant, each cable set is fully tested to ensure superior quality.
A variety of configurations suit a wide range of applications, including versions with or without a neutral, as well as models for boats with onboard isolation transformers or cable winch systems. Hubbell Marine offers both 125/250V and 120/208V configurations. A 15.2m extension cable is also available.
For more information contact Hubbell Marine Electrical Products, Tel: +1-475-882-4838 or visit www.hubbell-marine.com.
Hubbell Cable Sets deliver safety features
Twist-Lock 50A Cable play an important role in enhancing dockside safety for boat owners Despite a marina owner's best efforts, electrical problems at the pedestal may not be immediately diagnosed. Posted on 4 Aug 2023
Hubbell Marine offers a full line of components designed expressly for DC-powered reels Electric reels are popular with offshore fishermen in spite of sometimes being awkward to connect to a power supply. Posted on 16 Feb 2023
Durable 316 stainless steel construction delivers a long service life Seasoned mariners know that watertight integrity is critical for reliable shore power connections. Stainless steel 30A and 50A inlets from Hubbell Marine assure dependable performance in a timeless design that now benefits from recent technical updates. Posted on 6 Apr 2022
USB Receptacles keep phones and tablets charged
Now including USB Type A or Type C ports With both boats and boaters having become more connected than ever, there's never been greater need to keep portable devices fully charged while under way. Posted on 17 Mar 2022
Circuit Tester simple to use
LEDs on Hubbell Marine HBLT26CM11 Twist-Lock Circuit Tester glow bright enough to be seen in sun Multimeters are ideal for testing electric wiring, but their use requires specialized knowledge. Not so with the HBLT26CM11 Twist-LockĀ® Circuit Tester from Hubbell Marine. Posted on 5 Feb 2022
