New stainless Primus wheel is ergonomic and durable
by Martin Flory Group 23 Mar 2018 13:18 UTC
New stainless Primus wheel © Martin Flory Group
Few components on a boat are touched as frequently as its steering wheel. That's why Schmitt & Ongaro Marine designed Primus, its new cast stainless steel steering wheel, to deliver maximum ergonomic all-day comfort and engineered it for long-lasting, uncompromising durability. The visually striking wheel complements any helm and comes with a lifetime warranty.
The Primus is manufactured using a unified investment casting, including the integrated ring, for massive strength. NMMA type-accepted and CE certified, it's so strong, it greatly exceeds ABYC P-22 and ISO 8848 standards. Polished to a mirror-like finish, the 316L stainless steel provides superior corrosion resistance and has minimal maintenance needs. Satin-finish and powder-coated versions will be available in the future.
Available in 34cm and 39cm diameters, the rim is slightly thicker than most other wheels. At 28mm, the larger size lessens the hand fatigue that's common with thinner styles.
UV-resistant black Santoprene™ rubber provides all-weather control and comfort, and a dramatic counterpoint to the gleaming stainless steel. Underneath, finger grips deliver a sure, solid grip. It extends through the top of the rim, providing additional gripping surface. The contiguous piece of Santoprene also extends slightly under the spoke junction for a smooth, ergonomic fit. The result is an attractive wheel that matches any helm décor.
The Primus is available in three spoke configurations: slotted with decorative Santoprene inserts, open slots or solid. Edges have a slight radius for comfort, without sacrificing its markedly defined appearance.
The optional stainless steel Control Knob is large and comfortable. It's installed on a spoke, 19mm from the rim edge, to ensure it won't interfere with any controls or the driver's helm space. The installation has no visible protruding fasteners to catch clothing or hinder the smooth tactile experience. Schmitt designed the knob with glass ball bearings to eliminate corrosion and provide a lifetime of free-spinning.
The Primus incorporates the industry standard 19mm tapered hub. The durable stainless steel center nut works with all steering systems, with optional styles available.
OEMs appreciate the wide range of available options. Custom Santoprene colors are available in quantity, and the knob and center nut can be engraved with a corporate logo or model designation.
Ideal for center consoles, fly bridges, tower helms, RIBs and flats boats, the Primus is available for model year 2019, starting in May 2018.
Schmitt & Ongaro Marine manufactures superior quality steering wheels, horns, control arms and knobs, wipers and other high-quality components for recreational and commercial vessels. Known for its superior customer service, the company offers some of the strongest product warranties in the industry.
For more information contact Schmitt & Ongaro Marine Products, Tel: +1-717-431-2316; Fax: +1-717-431-2319. Email: or visit www.schmittongaromarine.com.
