Hubbell Isolation Transformers enhanced with auto-boost
by Martin Flory Group 20 Dec 2017 03:00 UTC
Hubbell Isolation Transformers © Martin Flory Group
Hubbell Marine has expanded its line of state-of-the-art Isolation Transformers with two new models enhanced with Auto-Boost. Now, in addition to safeguarding against stray current that causes galvanic corrosion and potentially deadly shock drowning, and reversed polarity that can irreversibly damage on board electronics, the transformer can automatically compensate for low-voltage conditions.
Hubbell Auto-Boost instantly evaluates the electrical system upon power-up. Easily programmed, the remote control unit can be installed up to 9.7m away. It can be set to remain in a static mode after initial start-up or dynamic mode, checking and adjusting the voltage every hour. It offers the ability to automatically compensate low voltage by boosting the output 12.5%. This can be programmed to boost from a minimum level of 190 volts up to 220 volts.
Hubbell Isolation Transformers are engineered to function with 50 and 100 amp systems, and are available in vibration-resistant white powder-coated steel or 316 stainless steel enclosures. They feature two full current-carry shields. Lighter and smaller than the competition, the 15kVA Isolation Transformer weighs 77kg and is 43cm H x 35.9cm W x 29.4cm D. The 25kVA unit is 113kg and 46.8cm H x 41cm W x 33.9cm D.
For more information contact Hubbell Marine Electrical Products on Tel: +1-475-882-4838; Fax: +1-203-783-9195 or visit www.hubbell-marine.com.
Hubbell Cable Sets deliver safety features
Twist-Lock 50A Cable play an important role in enhancing dockside safety for boat owners Despite a marina owner's best efforts, electrical problems at the pedestal may not be immediately diagnosed. Posted on 4 Aug 2023
Hubbell Marine offers a full line of components designed expressly for DC-powered reels Electric reels are popular with offshore fishermen in spite of sometimes being awkward to connect to a power supply. Posted on 16 Feb 2023
Durable 316 stainless steel construction delivers a long service life Seasoned mariners know that watertight integrity is critical for reliable shore power connections. Stainless steel 30A and 50A inlets from Hubbell Marine assure dependable performance in a timeless design that now benefits from recent technical updates. Posted on 6 Apr 2022
USB Receptacles keep phones and tablets charged
Now including USB Type A or Type C ports With both boats and boaters having become more connected than ever, there's never been greater need to keep portable devices fully charged while under way. Posted on 17 Mar 2022
Circuit Tester simple to use
LEDs on Hubbell Marine HBLT26CM11 Twist-Lock Circuit Tester glow bright enough to be seen in sun Multimeters are ideal for testing electric wiring, but their use requires specialized knowledge. Not so with the HBLT26CM11 Twist-LockĀ® Circuit Tester from Hubbell Marine. Posted on 5 Feb 2022
