New Posts New Posts RSS Feed: sailwave scoring question
  FAQ FAQ  Forum Search   Register Register  Login Login
 Post Reply Post Reply
Author
IRL41 View Drop Down
Newbie
Newbie
Avatar
Online Status: Offline
Post Options Post Options   Quote IRL41 Quote  Post ReplyReply Direct Link To This Post Topic: sailwave scoring question
    Posted: 01 Mar 10 at 10:01pm
Hi, I've been using sailwave for a while now and it is a
great resource for small classes like ourselves.
I have a question on the scoring which is as follows :
I am looking to score the number of boats that finished
+1 for a scoring code but it seems it is not in the list
of scoring method when editing the scoring. And I don't
think I can create such a formula either.
Could you tell me if it is possible to score that way ?
and if not who to contact to make a recommendation to add
this to the next build ?
Thanks
Back to Top
JimC View Drop Down
Really should get out more
Avatar
Post Options Post Options   Quote JimC Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 10 at 8:19am
Originally posted by IRL41
I am looking to score the number of boats that finished +1 for a scoring code
Yeah, its straightforward. Varies a bit with version though. In version 2 build 4 at least select menus
Setup/Scoring System/Scoring Codes tab.
Pick the code you want to change, hit edit, and select the method tab.
Go down the long and complicated list (which I usually have to read two or three times because the options are all substantially similar) and check against "ponts for place of (the number of finishers in the race plus N points) and then put 1 in the value box at the top.
Edited by JimC
Back to Top
Forum Jump Forum Permissions View Drop Down
Bulletin Board Software by Web Wiz Forums® version 9.665y
Copyright ©2001-2010 Web Wiz
Change your personal settings, or read our privacy policy
