New Posts New Posts RSS Feed: waterproof Plywood
  FAQ FAQ  Forum Search   Register Register  Login Login
waterproof Plywood
 Post Reply Post Reply Page  12>
Author
pij27 View Drop Down
Groupie
Groupie
Online Status: Offline
Post Options Post Options   Quote pij27 Quote  Post ReplyReply Direct Link To This Post Topic: waterproof Plywood
    Posted: 11 Mar 19 at 8:48am
I am looking to replace some plywood deck panels on a dayboat. Does anyone know of a good method of waterproofing or sealing these panels. They will be placed over the hull to give a level floor and if the bilge fills up with water then will be in contact with it.
Any help or suggestions please?
Back to Top
JimC View Drop Down
Really should get out more
Avatar
Post Options Post Options   Quote JimC Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 19 at 9:57am
Not much is really waterproof for ever. Will they just get wet or will they stay wet? If they'll be normally dry then any good paint system will do the job.
Back to Top
Groupie
Groupie
Post Options Post Options   Quote pij27 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 19 at 10:17am
This is decking planks around the centreplate, so underside will be in contact with bilge if boat left unattended for a while. otherwise just from spray or rain. Did wonder whether to use a wood hardener on the edges first and then a few coats of gloss paint?
Back to Top
Sam.Spoons View Drop Down
Online Status: Online
Post Options Post Options   Quote Sam.Spoons Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 19 at 11:34am
Is this the cockpit floor, Is weight an issue, if not what about fabricating floorboards from recycled plastic decking boards? https://www.kedel.co.uk/recycled-plastic-decking.html
Spice 346 "Flat Broke"
Blaze 671 "supersonic soap dish"
Back to Top
Groupie
Groupie
Post Options Post Options   Quote pij27 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 19 at 12:24pm
original planks only 10mm thick. use a movable small bar to hold in place.
Back to Top
JimC View Drop Down
Avatar
Post Options Post Options   Quote JimC Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 19 at 1:05pm
TBH, assuming its not a racing boat and you're concerned about budget I'd be inclined to use exterior grade ply, reasonable paint, and make up some templates so I can make new ones easily. Yes you could get into wrapping them in glass/epoxy and they'd cost 4 times as much and last 3 times as long. Sometimes you can overthink!
Back to Top
Rusty69 View Drop Down
Groupie
Groupie
Post Options Post Options   Quote Rusty69 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 19 at 2:04pm
Coat with epoxy resin.
Back to Top
Groupie
Groupie
Post Options Post Options   Quote pij27 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 19 at 2:26pm
Thanks Jim, sounds like an easier plan. cut to size and a few coats of gloss?
Back to Top
jeffers View Drop Down
Avatar
Post Options Post Options   Quote jeffers Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 19 at 3:11pm
Possibly some really thinned out varnish first too might help. Just to help seal the surface and the ends before you top coat. I did this on a boat I took back to wood. it really soaked in and where the paint has had a few knocks there is no sign of water ingress.
Paul
D-Zero GBR 74
D-Zero GBR188 For Sale
Ex Laser/8.1
Ex
Back to Top
Post Options Post Options   Quote Sam.Spoons Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 19 at 4:14pm
Thinest I found in plastic 20mm but there may be thinner out there, and they would last forever without any maintenance.
Back to Top
Forum Jump Forum Permissions View Drop Down
Bulletin Board Software by Web Wiz Forums® version 9.665y
Copyright ©2001-2010 Web Wiz
Change your personal settings, or read our privacy policy
