Help! I need to carry an anchor at my next regatta but where do I start?
by Marine Products Direct 27 Mar 10:30 UTC
Mantus M1 Quick Connect Small Boat Anchor © Marine Components International
It's not uncommon these days for class or events to specify the need to carry an anchor on board for safety reasons. In fact, when sailing in tidal waters especially if unsupervised you could say it's always worth carrying one on board.
Traditionally, anchors come with problems. Having an anchor that will hold position is likely to be heavy adding weight on board and be bulky to store.
Well, this is no longer the case. Some intuitive thinking and innovative design by the team behind USA manufacturer of high performance, quick setting anchors Mantus Marine, has created something rather special the Mantus M1 Quick Connect Small Boat Anchor range in stainless steel.
It may look like your average anchor but trust us it's not!
This quick-set anchor 'DIGS LIKE NO OTHER' and is ideal for dinghies, small boats and racing keelboats for three main reasons.
  1. There is no bulk - it packs flat.
  2. It's light - it is available in 3 sizes - 2.5lbs (1.13kg), 8lbs (3.6kg), 13lbs (5.9kg). Note the 2.5Ibs will hold a 30ft keelboat weighing up to 5 tons at anchor.
  3. It holds - it is designed to penetrate soft seabeds, hard or dense grassy bottoms and sets with unparalleled holding power.
The Mantus Boat Anchor has been extensively tested against the competition and will provide you with the best performance, guaranteed. No other boat anchor on the market can set as rapidly, reliably, and securely. Features include:
  • Formed out of high-quality 316L stainless-steel.
  • Surface hardened by shot-peening.
  • Surfaces electro-polished to provide maximum corrosion resistance.
  • Highly polished aesthetic.
  • No bolts required.
  • Shank secured with spring-loaded pins.
  • Roll bar stretches and locks into position securely.
  • Sharp-headed nose is precision machined to achieve the perfect chisel shape to achieve maximum penetrating power.
  • Disassembles quickly and easily for compact storage.
The Mantus M1 2.5Ibs stainless steel anchor also comes as a complete kit, with 50ft of 5/16 Double braid line & stainless-steel thimble, 1/4 Stainless steel shackle and nose cover, stored neatly in a PVC UV Resistant storage dry bag, you are just one click away from being ready for your next regatta.
marine-products-direct.com/product/mantus-m1-stainless-steel-dinghy-anchor-kit
Contact us for technical support, on +44 01202 600011 or email .
Find your local stockist at marinecomponents.co.uk or order now from marine-products-direct.com/mantus-marine-hardware.
Easy Med Mooring with the GHOOK from Boatasy
Mooring astern made simple with Boatasy We all know the sailing world is full of strange terminology, and we are about to introduce a new one – Boatasy GHOOK. Posted on 30 Apr
MCI appointed Exclusive UK Distributor for Mantus
Mantus Marine offer a full range of performance, quick setting anchors Marine Components International, leading supplier to the UK leisure and commercial marine market, has been appointed as the exclusive UK marine distributor for USA manufacturer of high performance, quick setting anchors Mantus Marine. Posted on 22 Mar
Docking made simple with Boatasy
The gamechanging modular boathook system from Boatasy For any boat owner, whether sailing fully crewed or shorthanded, one of the most challenging parts of any day on the water is the leaving and getting back to the dockside. Posted on 16 Feb
TEMO·1000 electric outboard motor defies the norm
Innovative, powerful, quiet and emmision-free TEMO are an innovative French company who look at solutions in a different way. We'd already taken a close look at the TEMO·450, with its extendable pole, rather than the traditional shape of engine housing at the top, and now we've tried the TEMO·1000. Posted on 2 Jan
Dripping shaft seal?
Replace your prop shaft seal with Lasdrop Dripless Shaft Seals Dripping shaft seal? It's time to service or maintain your propeller shaft seal! Posted on 12 Dec 2023
Winter maintenance tips
Get ready for winter with these top tips from Marine Products International It's that time of year! Winterisation is now in full swing and around the yard essential maintenance work is being undertaken. Posted on 2 Dec 2023
EchoPilot FLS 3D Gen 4 now compatible with Axiom
Take a look at the new Forward Looking Sonar from Daniamant Calling all explorers and sailors who like to venture away from the conventional harbours and crowded anchorings - you need to learn more about the NEW Forward Looking Sonar from Daniamant. Posted on 4 Sep 2023
Say goodbye to your old traditional boat hook
Compact lightweight boat hook from MCI Say goodbye to your old traditional boat hook that corrodes and occupies significant space when not in use and say hello to the future in boat hook design, the Revolve-Tec Rollable Boat Hook available from Marine Components International. Posted on 20 Jul 2023
On Test: TEMO-450 portable electric outboard
Lightweight, IP67 waterproof, extendable pole provides a whole new option for your dinghy The TEMO-450 is a portable electric powered outboard, which differs substantially from other outboards on the market. Posted on 6 Jun 2023
