Rig your fishing electronics right with Graph Power® Pro
by Connect-Ease 29 Feb 18:59 UTC
Rig Your Fishing Electronics Right with GRAPH POWER® PRO
Connect-Ease® GRAPH POWER® PRO Provides Anglers With A Quick, Easy, and Problem-Free System For Rigging Todays Advanced Fishing Electronics
PRIOR LAKE, MN (February 28, 2024) If you havent prepped your boat, its time to get your ride ready for great spring bites.
Some anglers may be looking at a recently-purchased boat wondering how best to rig it themselves, while others are talking with independent or marine dealership rigging staff and picking out the best rigging and power solutions.
Other anglers may be upgrading an older boat with new electronics for the year, staring down a maze of wires wondering just where to start
Whether you plan to fish out of a new boat or a seasoned rig this spring, its critical todays fishing electronics are rigged properly, have enough power, and are ready for hassle-free fishing. After all, nobody wants to be out on the water during a hot bite and end up messing around with amateur or problem-prone riggingwe just want our graphs and other electronics to work when we need them.
Along those lines, Connect-Ease is proud to offer GRAPH POWER PRO, a bullet-proof rigging system designed specifically for powering todays sophisticated graphs at the console or tiller position and on the bow, whether an angler uses Garmin, Humminbird, Lowrance, or a combination of brands.
Whether youre going to rig a new boat, re-rig an older boateither on your own or with the help of professional riggersConnect-Ease products promise problem-free operation of todays sophisticated electronics.
Wisconsin-based pro walleye angler and Connect-Ease pro staffer, Brett King, has been fishing tournaments for over 25 years. During this time, he's seen a lot of fads come and go. What hasn't changed over time is Brett's need for pure, clean, and reliable power in his boat to fish long days and cash checks. To rig and power his network of graphs, live imaging, and forward-facing sonar, Brett is a huge believer in the ease of Connect-Ease GRAPH POWER PRO.
Connect-Ease Founder, Cal Munkvold, remarks: Ive been an outdoorsman and big-water angler my entire life, so I knew there had to be a better way to rig electronics for everyone from the weekend warrior to the serious tournament angler. So we sat down and designed the trouble-free solution we would want to buy and install. The result became Connect-Ease products that allow easy, hassle-free rigging and powering of trolling motors, as well as GRAPH POWER PRO for todays advanced fish-finders, including all types of forward-facing sonar.
ABOUT GRAPH POWER PRO
From the get-go, GRAPH POWER PRO was designed to solve the connections and power issues associated with running todays sophisticated fishing electronics common on todays boats, providing clear, clean power and direct connections.
GRAPH POWER PRO is designed to work with all manufacturers of fresh- and saltwater marine electronics. GRAPH POWER PRO features marine-grade sheathed wire with multiple fused connections for your console and bow electronics.
Its plug & play. Rigging that used to take hours now takes minutes.
Connect-Ease uses the best marine-grade connections and heat-shrinkable crimped connections that are waterproof, reject RF interference, and stay connected on big water and waves. There is a 30 amp fuse at the battery and your choice of 3 or 5 amp fuses to use at the graph connections.
GRAPH POWER PRO FEATURES (19-22 CONSOLE BOAT KIT)
  • HOUSE CONNECTION: 30 Amp fused quick-snap connection at the batteryno switch needed
  • EASY FEED DESIGN: Bullet connections and sheathed housing for hassle-free installation and snaking through tight spaces
  • PRO CONSOLE BACKBONE: 16 feet of 8 gauge sheathed marine-grade wire
  • PRO BOW BACKBONE: 13 feet of 8 gauge sheathed marine-grade wire
  • DEVICE PROTECTION: Your choice of 3 or 5 Amp at the fused connections to meet manufacturer recommendations
  • HEAT SHRINKABLE BUTT SPLICES: Weatherproof, vibration-, and corrosion-free for a lifetime of on-the-water use
GRAPH POWER RIGGER FEATURES (14-18 RIGGER BOAT KIT)
  • HOUSE CONNECTION: 30 Amp fused with quick-snap connection at the batteryno switch needed
  • RIGGER CONSOLE BACKBONE: 13 feet of 8 gauge sheathed marine-grade wire
  • RIGGER BOW BACKBONE: 8 feet of 10 gauge sheathed marine-grade wire
Not only do Connect-Ease GRAPH POWER PRO kits make rigging fast and simple, they provides protection and limits RF interference to power your graphs, pucks, GPS, and NMEA boxes directly from your battery to meet manufacturer recommendations.
The result?
Not only is rigging faster and trouble-free, you get the best possible clear and defined imaging on your graphs once installed, especially helpful with side-, down-, and forward-looking sonar technologies. GRAPH POWER PRO was designed to provide clean, reliable power to the critical and power-hungry electronics found on todays tournament boats, so that translates to the very best rigging solution for every customer, no matter how often youre on the water.
Our pro anglers and guides have learned through years of experience that to get the best performance out of todays electronics, its best to use a GRAPH POWER PRO kit connected directly to its own dedicated lithium battery.
Anglers can also visit Connect-Ease in person at the Bassmaster Classic Expo, Booth #116, March 22-24, in Tulsa, Oklahoma. Or visit www.connect-ease.com
GRAPH POWER PRO kits are also available for tiller models
FacebookYouTubeInstagram
