A Class Catamaran World Championship at Yacht Club de Toulon - Day 1
by Gordon Upton 11 Sep 2023 08:02 UTC 7-15 September 2023
Following a lovely champagne sailing week's run up to a major championship, it's obvious now, to anyone with any wind connection and recent experience, that the actual race week will inevitably be one where total near windless conditions shall inevitably prevail.
There's probably a law or something describing the phenomena. It's like there's only so much wind available, and if you've used it all up playing in it, then that's your own fault. Like a sort of wind version of that immersion heater you had as a kid, that your dad switches off before you have a bath, so it suddenly goes all cold after so long and ruins bath time.
That was day one of the A-cat World Championships at the Yacht Club de Toulon, on the stylish Cote D'Azure. There are probably worse places to be floating about like a bunch of hot ducks though.
Race officer Corrine Aubert had made the call to delay the start until the afternoon as a breeze should have arrived by then. 13:30 was the time set for the sequence start. The wind was about 9-13kts, Southerly as the gun went. The 80 boats of the Classic non-foiling fleet all started cleanly, slicing through the ridiculously Azure blue waters of Toulon Bay with the ease and elegance that it seems only the A-Cat can do when going upwind. Gradually the boats started tacking off to the right until a twin fleet emerged, with one or two undecided up the centre. At the top mark, it was the right sailors that gained and when the others joined into the lay line, many were ahead of them in the orderly stream of boats around the top mark and the spreader. Veteran A-Can Ace Scotty Anderson, Exploder AD3 AUS 31, led the around. He was being chased by Manuel Vaccari, Schurer G6 ITA 5. Marco Radman ITA 55, Mathias Dietz GER 3 and Gustavo Doreste ESP 72.
Two more laps followed as the wind swung right and then right again, necessitating the installation of a new top mark. Those who chose the middle were probably best served as their gains and losses would be less pronounced. The small tactical battles were played out throughout the fleet. The Classic version of this boat is perfectly suited to this type of close quarter tactical stuff. The Southern German lake sailors are pretty much the masters of this light breeze chess, and one can look at a result sheet from a large event and sometimes work out the wind merely from the results.
At the finish, Scotty mad managed to hold off the strong challenge from Manuel enough to get over the line for his bullet. A little further back, Gustavo and Marco were match racing, all down the last leg. In fact this allowed Mathias to catch up, and with 100m out, I think they suddenly realised his threat as the stopped their tactical games and accepted their positions of Gustavo in 3rd, Marco 4th and Mathias 5th.
Race two nearly got under way until a massive shift hit the already considerably biased line within the last minute, and the PRO decided to cancel that start. This was fortunate as several boats has bunched up around the stern of the committee boat, with considerable screaming emanating from Micky Todd, ESP 5, who had been pushed out and found himself the wrong side of the committee boat. Serves him right really for changing his tactics, as he's usually found right at the other end of the line.
The next start was clean and all swished away upwind. This time Manual was first at the top, closely followed by Gustavo, then Mathias. Scotty had got himself stuck on a second row of boats at the start and had to fight through several ahead to get towards his desired position. The 3 laps continued in a similar vein. The wind was sufficient to Trapeze upwind, which is always nice on an A-Cat, indicating its usually at least 8 knots on the nose. In one lap, the middle of the fleet suddenly found that an earlier sailor had speared one remote control bottom mark and ran off with it. Several were already committed to that mark, so has to hunt him down in order to round it as he was unable to reverse off it because as soon as he tried, the motor unit, seeking it's original position, just drove the thing back up his hull! GBR sailor Hugh Macgregor GBR18, was one befitting from this, and gained several places by suddenly switching his chosen mark to the other side after seeing the ensuing and amusing drama.
However, the battle at the front was hotting up. The likeable veteran German Champion Mathias was doing what he knows best, as there were his conditions. He hunted down the European Classic Champ, Gustavo, on the last downwind and was closing in on Manuel, but the finish line just saved him, giving him his first bullet too. Scotty had also passed Gustavo for a good 3rd place.
So at the close of play of the day in the Classics it was Manuel lying in 1st, Scotty 2nd, Matthias 3rd, Marco 4th and Gustavo in 5th. Much is left to play for. Reigning multiple Champion, Andrew Landenberger has a mare of a day and languishes in 16th. Two more races are planned for tomorrow.
Over on the Open fleet, they had to float around in the heat after being released from the beach in expectation that the Classics would have finished, but it was not to be. In the end they got a start in, and they all went up wind in their floating mode, which is noticeably slower than the Classic boats, owing to their larger foil areas and flatter rigs just slowing them down. Again it was a left and right thing, with the left proving the better, and Bailey White, USA 320 rounding in the lead, closely followed by another GER Lake sailor light wind specialist, the elfin Katina Brunner, battling Swiss Champ Robin Maeder. But then the race was abandoned as the wind had dropped to illegal class limits, so the all went home, sadly dragging their teddies behind them.
This was the opening day of the 2023 A-Cat Worlds. The Race officer did her best and managed 2 races at least. It resumes, probably in a similar vein tomorrow, but it's looking quite tactical this year.
Full results so far can be found here.
A-Class Cat North American Championships overall
Racing wrapped up on Saturday with a total of 7 races being sailed The A-Class Catamaran Admiral's Cup and North American Championship wrapped up on Saturday, April 13 with a total of seven races raced in the North Americans, allowing one throw-out. Posted on 17 Apr
A-Class Cat North American Championships update
After two days of weather delay, four races were completed After two days of weather delay, the A-Class Catamaran North American Championships got off four races in a moderate 5-18 MPH with light chop and significant wind variations on the back end of a weather front. Posted on 13 Apr
A-Class Catamaran interview with legend Ben Hall
Otherwise known as "The Admiral" On the heels of the wildly successful Admiral's Cup in A-Class Catamarans at Pensacola Yacht Club on April 5-7, it only seems fitting to conduct an interview with none other than Ben Hall, otherwise known as "The Admiral". Posted on 11 Apr
A-Class Admiral's Cup at Pensacola overall
The traditional warm up event for the North American Championships concludes A-Class Catamaran sailors enjoyed beautiful Pensacola Bay in eight races April 5 - 7 in the 2024 Admiral's Cup (the traditional warm up event for the North American Championships). Posted on 9 Apr
Oldest videos of racing catamarans
We start in 1965, covering Hobie, Shearwater, Prindle and C Class, then the Worrell 1000 We delve into the past, and round-up all the videos which show racing catamarans, including Hobie cats, Shearwaters, Prindles and C Class, from the 1960s to the 90s. Plus some Worrell 1000 history. Posted on 7 Apr
A-Class Admiral's Cup at Pensacola day 1
Nine boats racing in the foiling fleet and fourteen in the classic fleet A-Class racers got right into the action on Day 1 of the Admiral's Cup on April 5, 2024, hosted by Pensacola Yacht Club and led by National Race Officer, Hal Smith and his team of skilled volunteers. Posted on 6 Apr
Calling all A-Class Catamaran sailors
A-Class Admiral's Cup and North American Championship to be held at Pensacola Yacht Club Register now for the A-Class Admiral's Cup (April 5-7) and North American Championship (April 9 - 13) at Pensacola Yacht Club. Posted on 25 Mar
Allen Endurance Series 2024 dates announced
Promising a thrilling and competitive season-long event for catamaran and skiff sailors The Allen Endurance Series proudly unveils its 2024 schedule, promising a thrilling and competitive season-long event for catamaran and skiff sailors to compete for. 2024 marks the 5th year of the premier long-distance sailing series. Posted on 8 Feb
Australian A-Cat Nationals at Lake Macquarie overa
The final day of a regatta can be a strange one The final day of a regatta can be a strange one. Sometimes, it all comes down to the last race as in the Toulon Worlds, and sometimes the last downwind leg of that race too, as we saw in Houston. On other occasions, the frontrunner is already decided. Posted on 14 Jan
Australian A-Cat Nationals at Lake Macquarie Day 4
Fleet arrive energised after a two hour delay waiting for the wind The penultimate day at the AUS A-Cat Nationals as another fun day on the lake. Although the predicted wind didn't seem to come up to the promise of 2 kts more that yesterday, it was still an acceptable 8-11 knots. Posted on 12 Jan
